1 - 20 of 23 Posts
While you're at it, yaw rate sensor might also be failing or become loose. Wheel speed sensors should throw their own codes, so they are unlikely but still possible point of failure...
As for the wiring harnesses, they are, as you prolly know by now a bitch to check. Especially if the problem is intermittent.
Check all the connector pins (especially on modules) with a magnifying thingy for signs of sparkin. IIRC older GC models had a habit of arcing in the connectors.
2009 srt8 Jeep Grand Cherokee 426 stroker
Discussion Starter · #13 ·
I will check all of that out. I really appreciate your help thank you hopefully I’ll find the gremlin.
· BlaBlaBla
I had a misaligned wheel speed sensor that totally screwed up my Jeep. It would start, go into D but as soon as about 5mph would go limp. Threw every code BUT a sensor code.
Highly unlikely you have 3 failed ECMs. How was it determined they were failed?
Reactions: White Elemant
Discussion Starter · #17 ·
The first two were sent off to a computer shop in Pennsylvania that said they were bad and not repairable, the third one going through the steps of diagnosing it says my ecm is bad. I’m in the process of going through all the wires and checking for continuity. I replaced the yaw rate sensor no change and I tested the wires from abs to yaw rate sensor continuity is good. The shops I’ve had it at supposedly did everything I’m going to.
1 - 20 of 23 Posts
