1 - 3 of 3 Posts
Everything works perfectly.
Asking 275.00 plus shipping and PayPal.
I am not on the boards much so Please contact me at [email protected] or text at 253-380-3488. The air fuel sensor has been extended to 4 feet to accommodate headers.
Pictures here: https://picasaweb.google.com/1059130...589082/Dynojet
Thanks.
Widebandcommander Product Information
The Wide Band Commander is a tuner’s best friend. It provides a complete picture for proper air-to-fuel ratio analysis. Unlike many “Air/Fuel Systems” on the market that use inferior narrow band technology, this unit has the capability to read from 10.1:1 to 18.1:1 using a Bosch 5 wire LSU4 wideband sensor. This is by far the most complete kit available on the market today.
Once installed, the Wide Band Commander provides an “in-vehicle” dash mount AFR display gauge with a built in warning light, as well as data recording which can be retrieved and analyzed using the supplied software package.
• Programmable output for solenoids, relays, etc.
• Programmable warning light output (built into supplied sensor)
• On board memory allows data to be logged without the use of a laptop/PC.
• Download the data at your convenience!
• Log file data can be played back in the software or exported as text.
• 0-5mA/0-5v output for aftermarket engine management/data acquisition systems
• Easy one-wire RPM & TPS hook up
• Durable enclosure and wire sheathing for years of trouble-free operation
• Utilizes inexpensive, readily available replacement sensor
As a world leader in motorsports chassis dynamometers and diagnostic equipment, Dynojet Research Inc. is pleased to announce the Wide Band Commander.
Once installed, the Wide Band Commander provides an “in-vehicle” dash mount AFR display gauge with a built in warning light, as well as data recording which can be retrieved and analyzed.
pics dont work
How accurate is the sensor? I know with the Autometer wideband, you can't extend the wires. GLWS.
1 - 3 of 3 Posts
