Hey guys,
Bought these Fuel rails a few months back and decided to go another direction. So they are up forsale brand new in the box and have never been installed.
The Fuel Rails come in a Bright dip anodized clear finish.
A fuel pressure gauge port is available on the passenger side fuel rail using the 1/8" NPT Port as well..
Asking 160 shipped here in the US....
Features
CPR FUEL RAILS provide increased fuel flow and a better balance to each cylinder. CPR rails will work with all sizes of injectors and can handle up to 4,300 HP!!! Available in polished clear anodized rails. All tabs are welded and clear the coil packs. They also fit all OEM and most aftermarket intakes.
Lifetime warranty through CPR
It is made from billet T-6061 aluminum, high polish then brite dip anodized
Works with all popular intake manifolds without any filing or grinding that most other rails require
Compatible with return or return-less fuel systems
Return-less fuel rails feature area for mounting the OEM fuel pressure sensor relay.
Unique O-ring seat for the AN fitting and NOT NPT
Clearance to fit most aftermarket Superchargers
Works with all sizes of fuel injectors
5/8" ID (not 1/2") handling up to 4300HP!!
Fully Welded intake manifold attachment brackets
Hardware kit for direct bolt-on mounting to manifold.
Features
