1 - 20 of 198 Posts
http://www.cagannyc.com
Hi Everyone,
I would like to share my proud joy, my work in progress. Being build by Jim @ True Street Performance.
First of all...
Jim,
I truly appreciate everything you have done. All your hard work and your experience is my gain! You made a self made man get teary eyes on his way home with this monster! I could not resist my overwhelming emotions of accomplishment! I think you are a true gentlemen and a very skilled individual. I am glad I made the choice to drive all the way up to LI from NJ that rainy day 3 years ago just to meet you. Since then I have been a happy customer and your friend!
THANK YOU FOR BUILDING ME THIS MONSTER! CAN NOT WAIT FOR PHASE 2!
That being said... YES! this post is only for the phase 1 of mods and until now accomplishments! I will keep this thread alive as my build thread and keep you all posted!
TRUE STREET PERFORMANCE TURBO BUILD
Jim will fill in with more technical information since I am not as tech savvy as some peeps here. How ever I made a detailed list of mods which are below...
2008 JEEP GRAND CHEROKEE SRT8
PHASE 1 HP - DONE!
Restricted to 10 LBS of Boost with Pump Gas: 746 WHP Approx: 880+ Crank HP
PHASE 2 HP - COMING SOON...
22 LBS of Boost with Race Gas... Coming soon!
PERFORMANCE / COSMETIC MODS - PHASE 1 DONE!
True Street Performance Single Turbo Kit. 88MM Bullseye BatMoWheel Turbo - Billet parts
Arrington low compression 426 7.0Liter Short Block - 9:1 Compression Ratio
Engine Billet Main Caps
Mahle Pistons
Custom Crower Turbo Cam
Aeromotive Fuel Pressure Regulator - Dash 8 Feed / Dash 6 Return
2 Aeromotive 340 Pumps with Modified Custom True Street Performance Hat
Fore Fuel Rails from Demon Performance
Fuel Injector Clinic 110 Pounds
Arrington 90MM Throttle Body
Arrington Stage 2 Intake Manifold
Arrington Upgraded Heads
Paramount Stage 5 Transmission
Paramount Dominator Series Stall Convertor
Wavetrack Rear End
Moser axles
Quicktime Performance Electronic Cutouts with a Side Rocker Panel Carbon Fiber Exhaust Exit.
Trufiber Charger Ram Air Hood
Black Ops Full Carbon Fiber Venom Hood
PML Dif Cover with Heat Sinks
K&N Crankcase breather filter
180F TSAT
Diablosport Trinity, AJ the Hemi Tuner Tune
Innovate Motorsports Air/Fuel Ratio Sensor
Billet catch can
NGK Iridium Sparks
Bosch Battery Replacement
Borla S High Flow Catback Exhaust System with No Cats
R1 Cross Drilled and Slotted Discs
Stoptech Pads
QA1 Rear Adjustable Shocks
Eibach Pro SUV Lowering Kit
BWoody performace sway bar links
BWoody 06-2010 Jeep SRT-8 Rear Lower Control Arms
BWoody Performance Jeep SRT-8 Rear Track (panhard) Bar
Stage 6 Driveshaft Loop
Vredestein Sessanta Ultrac Tires
Gloss Black Powder Coated OEM SRT Rims
Carbon Fiber Dashboard Trim
MyGig Lock Pick with Front Bumper Camera
Kuda iPhone dock
Billet under hood package
Aeroforce Interceptor dual digital gauges with THM A Pillar dual gauge pod
HID Fogs, LED Taillights and HID Reverse Lights with LED rear fogs
Stillen Head Light Covers - Carbon Fiber Wrapped
Carbon Fiber Wrapped Mopar Spoiler
Carbon Fiber Hydro Dipping - Engine Bay and Various Parts.
PERFORMANCE & COSMETIC MODS PHASE 2 - COMING SOON!
Race Tune with 22LBS of Boost - HP TBD
2 Step Launch Control
10 Point Custom True Street Performance Roll Cage.
SPA extreme 2.5KG GAS Fire Suppression System
Oil / Transmission Colling System
Upgraded Engine Cooling System with on Demand Fan Switches
Anze Motorsports / Penske 3 way - Full Adjustable Racing Coil Over Suspension.
OMP WRC Carbon Fiber Bucket Race Seats
OMP 5 Point Harness
E-Boost Boost Controller
Demon Performance Weld Drag Rims / Drag Radials (Race Application)
Nitto NTO5 Front / NTO5R Rear Tires (Street Application)
True Street Performance 2 Piece Rotor Set
More to come!
PICTURES:
MORE INFO IS COMING SOON! MORE PICS AND VIDEOS ARE COMING SOON! INITIAL DYNO RESULTS ARE ON IT'S WAY! TRACK RESULTS COMING SOON...
P.S. This is my build thread... Please kindly ask all your technical questions: HERE
STAY TUNED!
Nice build looks nice and clean brother!!!
Silver & Satin
All smiles from me! Excited to see this beast done!!!
Discussion Starter #8
Thanks man! Jim did an amazing job with this design. As you can see nothing on the bay was hacked! That big 88 sits where it needs to sit in a perfect way! Pipes were designed very efficiently. The routing and fabrication is flawless. He knows I like CF! They did special heat coating / CF hydrodip, matching my color scheme / high heat clear over my cold pipes! This kit does not only perform insane it looks OEM and clean!
Can't go wrong with Jim and True Street Performance! I wish I was closer! Congrats and enjoy that new power!
Congrats Cagan, have personally seen the work done and it looks incredible, and the numbers on 10lbs are awesome! Hats off to you and the guys over at True Street for making everything happen and producing a monstah
-Steve
OMG Cagan, I knew it would have to be you getting this first TrueStreet turbo build...This comes as no surprise to me ;) LOL Anyways man, that build looks fantastic, one of the best I've seen. Jimmy Boy huge congrats on a sweet build...Keep up the fantastic work :rocker::rocker::rocker:
Discussion Starter #17 (Edited)
-Steve
Steve!
Truly appreciate it man! Thank you for some of you who has seen the built, kept it quiet for me... I wanted to brag when it was right... Jim's work speaks for it self as you say...
Discussion Starter #18
:bouncy::bouncy::bouncy: I got lucky!!! Thank you for kind words man... can not be more happy!
Discussion Starter #20 (Edited)
Wow what a clean build! You daily driving that monster?
I def can, but I have an SRT4 for daily... Just drove all the way to Moparpalooza and came back. It is surprisingly civil off boost. I did enjoy a 70mph ride with AC / my music on and loose anyone I wanted if they pissed me off!
1 - 20 of 198 Posts
