1 - 12 of 12 Posts
Which spring gets the nod for:
Ease of install
Ride
Ride height
It seems the Eibach require a bunch of BS to get right.
Install is the same....
Ride quality.....Bwoody is softer but the 1.7" rear drop bottoms more and bottoms harder.
Ride height.....here is a pic of my silver Jeep with the Eibachs and Ekaz's Jeep with the RM/Bwoody 1.0"f/1.7"r springs:
Discussion Starter #3
Thanks for posting that picture!
Also, did you just cut your factory bumpstops? From what I've read if I get the Eibachs and not do that I'm gonna have a rough ride.
If you get a new Eibach kit, you just don't use the tall spacers that they send you. Just use the smaller cup and the Eibach bumpstop.....you either need a smaller bolt, or I think you may be able to use the factory bolt.
My kit is one of the very first ones before they included spacers, so I just cut my factory tower down and used the full Eibach bumpstop.
Discussion Starter #5
Thanks very much for the quick help, sincerely.
There's a hot rod shop near me that I'm gonna have put them on, I'm sure they can get the bolt that I may need.
I read a thread the other day pertaining to bumpstops that honestly had my head spinning....lol
Eibach may be more complicated to install with all BS
but it won't rust lie bwoody spring...
I would go with more reputable brand
damn that silver jeep looks sick. i want mine to sit exactly like that. What do you have in the front and rear? im doing that exact set up
Dan (silver Jeep) has the Eibach springs in his Jeep....the other one has the Bwoody's.
Eibach has no BS install issue , like Dan said just DO NOT USE THE BIG SILVER SPACER . All is required is a 2" long bolt to fit the smaller spacer and can be found at any parts store . So basically bring in the long bolt that comes with the kit and ask for the same bolt but in the shorter size , I used a 2" long one found at pepboys .
Thanks M4x! Thats all I needed to hear. I'm ordering Eibach's this weekend!!
Can I get a confirmation on the part #? ...2892.540
1 - 12 of 12 Posts
