1 - 12 of 12 Posts
Here are a few pics...the washer tank is at the painter being painted black...in the pic with the wires striped I went this way because of the amoutn to moisture up here I did not want to use the tap clamps that came with it so I just did it more permanent.
all in all a very easy install..almost took longer to empty the washer tank.
Looks good ! A true CAI : )
Looking good Ross.
Reactions: YKPizzaGuy
Looks good. I know what you mean about draining the bottle lol.
Down the road when I figure a better washer solution out I'll just extend the factory harness and OEM connector. Splice in some wire, soldered and heat shrink wrap the connections.
1 - 12 of 12 Posts
