QBN,
There was a thread showing the install documents for the Bwoody end links. It shows the Passenger side link on the outside (closest to wheel), and the driver's side on the inside. This seems to be the opposite of the way yours is installed. The way you seem to have described it, is that your drivers side is inside, and the passenger side is on the outside, correct?
Can you move both sides to the inside of the bracket? It looks as if you were to invert the link and flip it around, the offset would take care of itself and both end links could be moved to the inside. Are the upper and lower ends of the end links two different bolt sizes? If not, this should work. I was just curious if you, or anyone else, tried this yet?
I was washing the ride today and was taking a look behind the wheel at the stock links, and it seems very tight with the GY run-craps. Considering in stock configuration that both end links are on the outside of the bracket, it seems that it would not matter if the Bwoody's are on the inside or outside considering the Bwoody links relocates one side to the inside of the bracket.
