So like so many others I had the bad brake squeal. :boohoo:
I found the answers in this forum and I know there's a lot of other people looking for a solution so I will sumarise what worked on my rig.
-R1 concept rotors drilled and slotted
-Cadillac cts-v rear pads (forget the year and part no. It's on the forum just look)
OEM jeep brembo front pads - ya that's right
Loctite brake quiet liquid compound applied between the back of the pads and the shims.
That's it.
First off I would like to thank builder bill for reminding us in a post that nothing stops as hard as OEM jeep brembo pads, the fronts don't squeak. So if your looking for a cheap solution like $100 front pads that will compromise braking power that's not what I did. The caddilac pads have been a topic in this forum and a lot of people seemed confused about if they should buy OEM caddilac pads or another brand. Well I bought OEM caddilac from the dealer. They are brembo and I want a quiet brake that has STOP. The R1 concept drilled and slotted rotors have been identified as an awesome rotor and it is, plus it looks great. I think that the OEM rotors are of a shitty material and combined with the rear OEM rear pads cause the squeaking. However just to note for research purposes I put in the pads First and did not change the rotors, I drove for 2000km before I put my rotors on and they did not squeak once. In my opinion the drilled holes and slots may change the possible harmonics of any high pitched vibrations come out as the shreek sound, but this is just my opinion.
Now I used this Loctite brake quiet liquid compound which again was identified in this forum as something that worked. From what I can see it's basically a compound that glues the shim to the pad and provides a damping effect. It dries very sticky and there won't be any vibration / harmonic squeal between the brake pad and the brake shim. Now someone may say that this is hiding a problem or that it would mask another problem with what I put on my rig. The thing is it costs less than 5 bucks for the compound and it makes sense to me.
So now after 6000km driving I still haven't heard a single squeak. My braking power is awesome. No compromise.
The rotors look much better than OEM.
Yes this wasn't the cheap route, I don't think anyone likes paying the nearly 500 bucks for front OEM brembo pads but if they are good enough for builder bills jeep they are what I want.
You may be able to get away with running stock rotors but I went with new R1 concept rotors.
The Loctite brake quite compound is good.
Use OEM caddilac pads for the squeaky rears.
Fixed long term.
Thanks to all the others that figured this stuff out so I could solve my squeaky brakes the first try.
Frank.
That's it.
Fixed long term.
Frank.
