1 - 5 of 5 Posts
Need/want to replace battery...I have an 07 with original battery and starting to act up.should have been changed a while ago. Anyway, should I stick with stock or get an optima..their website doesn't give grand cherokee option
I just went with a diehard as it fits in the case. Some are a lot lighter than stock n the sears diehard but they dont fit in the stock case as there smaller and some post are switched.
I have always gone with Optima on my previous car, because I only had to do it ONCE. Bought the red tops over 8 years ago for my wrangler (dual set-up for the winch) and I have never had a problem. Even when a buddy of mine killed my primary from leaving my running lights on over the weekend, back-up batt. started it no problem and the primary still works fine after recharging by the alternator.
I have seen some people here use an Optima in their Jeep. You can make it work, it just takes a little fabrication for some spacers so it doesn't fly around your engine bay ;)
1 - 5 of 5 Posts
