There are electric motor/servo modules that run the dampers on these cars, not vacuum motors as in the older ones. One way they state to test them is to switch the connectors around between actuator modules to determine if it the module or the controller.
Edit - I see you said auto climate control. I only have the manual for the manual climate control so it is possible the automatic uses vacuum servos but I doubt it.
