1 - 8 of 8 Posts
Is anyone using the arrington throttle body with built in nitrous ports.
I just installed one but haven't sprayed yet. Not much info to be found on this piece since it is expensive and not a bunch of guys spraying. You could save cost by just using a plate or nozzle and probably get just as good results. The only reason I chose this was because I could not use a plate in my current setup. Should be good for up to a 200 shot, and it does clean up the engine bay.
i just installed one but haven't sprayed yet. Not much info to be found on this piece since it is expensive and not a bunch of guys spraying. You could save cost by just using a plate or nozzle and probably get just as good results. The only reason i chose this was because i could not use a plate in my current setup. Should be good for up to a 200 shot, and it does clean up the engine bay.
...pics! :)
Sorry nothing special...it looks like a regular throttle body with ports machined in it for nitrous and fuel. I do not have my nitrous system installed yet.
oooh well pics for sure when u get ur Nitrous set up !
1 - 8 of 8 Posts
