41 - 56 of 56 Posts
I'd say that it's a touch lower then mine and I have the mopars.
Man that looks perfect! Are those 22's?
Which mopar kit did you go with? Sorry for all the questions I'm new to the drop scene so as much info as you remember I'd really appreciate.
I was looking at the eibach kit that does .7 / 1.3 " - is that about what yours is?
Jay
Yep the mopar is .7/1.3 as it's just the rebranded eibach kit. They are 22s with 305/35s. There's more pic from a few different angles on my other posts.
Thanks guys. It looks killer.
I'm looking at some 22's now and it's confusing which offset to get so I have a nice flush sidewall to fender.
Any recommendations on some affordable black or dark grey options?
Avante Garde or Velgen has great options
The rims you run now, are they what you were looking for when this was posted? Or are you looking to change these? Any specs on your current rims? I really like this setup. It seems there's 4 or 5 rims most people run, it's nice to see something else. I had the thought for your setup in my mind for so long, it's nice to finally see it.
Thanks,
I'm about to purchase some new wheels. Going with 20x10 +40 avant garde m652. I see no one really likes to give offset out to people so it's extremely hard to do research.
Someone mentioned early in this thread a +40 is perfect for the wk2 but if on road Magnet extremes there will be rubbing. Well I'm on road magnet extremes, how ever I dont believe there will be issues. I think it wheel width has to also factor into that. If I'm not rubbing with a stock 20x10 +50 then I dont believe a +40 wheel will change that. Same overall height
Anyone chime in with their experience
Well finally got my wheels on. Offset is little more aggressive to clear brakes. 20x10+25 and 20x10+35
The tires now sit flush with the outside of the fenders. Because of how low I am and how far the tire is now pushed out. Might need to add little bit of camber so the tire doesnt come in contact with the fenders. Wish I was just able to roll the fenders
227620
front
227622
Back
227623
295/40/20 nitto nt555
old post I know.
Hey Travis, I've been searching the internet to help figure out what offset I'll need to fit 315s under my SRT.
I seen that you are running two different offsets front and rear, the wheels I'm looking at are a 20x10.5 +35 all around and wanting to run a 315/35-20 I'm also lowered on Eibach Pro's.
As far as I can tell I should be very close to your setup, not quite as tall a tire but slightly wider, my only concern is my offsets where you did two different and I'm looking at the same +35 all around. Any input or thoughts on this I would appreciate.
Thanks (y)
Edit, the more I look into it, I'm leaning towards a +40. try and tuck the tires in a little more
old post I know.
Thanks (y)
You can run the same offset all around it just depends on the wheel style. You have to be careful as too high of a offset and your wheels won't clear the front brakes. My 20x10 +35 won't fit on my front as it hits the caliper.
My buddy ran 20x10.5 +35 and they were okay but again it depends on the wheel style
That gives me more to think about, the wheels I was going to order are drilled when ordered so no returns, would hate to get them and they don't fit.
Thanks 👍
41 - 56 of 56 Posts
