I finally got around to installing my 9500ci over thanksgiving weekend. I wanted to go more agressive with the location of the display and control unit. I had originally planned on flush mounting them above and below the HVAC control, but the control hangs over the "blank" spaces in the bezel more than I anticipated. Unfortunately the grill slats are not wide enough to fit the laser shifters so some time with the dremel tool was required. I mounted the radar receiver on the driver side of the ACC "eye". I added the LED above the EVIC which turns from green to red when there is a viable threat. The gps receiver is on the dash next to the middle speaker. One issue is that the rear shifter makes a weird shadow on the license plate, so I need to adjust that (I may try adding a small LED bar under the shifter). I plan on running this along side my V1 for a while until I am happy with its performance. One good thing is that I do not get false signals from either the ACC or blind spot monitoring.
Pictures below (cell phone camera) also realized no GPS pictures. Not a professional install, but I'm pretty happy with it.
Display
Controller
Front Shifters
Radar Receiver (not a good picture)
Rear Shifter
Display
Controller
Front Shifters
Rear Shifter
