1 - 5 of 5 Posts
I really want to add some output to my otherwise stock sound system and do not want to add a subwoofer enclosure in the back. Can the audio gurus weigh in on the pros and cons of installing one 6 1/2" subwoofers in each rear door in the factory speaker locations. Will the subs just rattle the door panels without a box?
If you sound dampen the doors well, you should get decent output from the pair.
Just make sure you feed them a good amount of clean power and it should be pretty good.
I haven't had the rear doors apart yet, but if you could fit an 8, I would go with that instead.
I have had good results from Stinger Roadkill in my previous car.
I think this time, I will either use Second Skin Damplifier pro or AlphaDamp.
1 - 5 of 5 Posts
