1 - 20 of 20 Posts
Had the Vreds installed today. I don't think anyone has had 315s installed on the Reps yet so I thought I'd report out.....
The 265s went on the 9" fronts with ease. Mounting the 315s on the 10" rears took a combination of finesse and elbow grease to get the beads to seal properly. I took them to a shop with lots of experience working with larger wheels, ....... They did a great job, and while I was pretty nervous watching them work with the prybar, when they were done there wasn't a scratch anywhere. Phew!
They look freakin awesome. Waiting for Spring, but I may have to bolt them on in the garage for a sneak peek :)
315
I thought we coudlnt do 265/315 combo?? Or can we? 275/315 is wut i have
O nvm ur on 22s :)
Will this be the same overall diameter as the 275/40/20 front 315/35/20 rear on the stock rims?
Discussion Starter · #9 ·
Front Diameter is 29.3", rear is 29.4". It's only a 0.48% difference. This is the closest match you will find for a staggered 22" set up.
Discussion Starter · #11 ·
Probably not until March when the weather improves here. I may mount one side when we get a sunny day just for a look :)
Pimpn8Easy runs this combo without rubbing, but on different 22s. I've done a little proactive prep on the passenger side rear where rubbing tends to occur with 315s (I moved sway link to the inside and reshaped the plastic well a bit. Should be all good. I'll update when I get them on......
Discussion Starter · #14 ·
My bad! That combo is closer. Great to hear they are working well. Never even thought of going lower pro than 30s! The diameters are about an inch shorter than the combo I got. Do they fill the wheel wells ok? Any pics?
Yeah unfortunately Pirelli doesn't make a 30 series. Manny and I both are lowered on Eibachs and they look sweet. Just the right amount of gap between the top of the tire and body. I don't have any pics yet but I think Manny posted some.
Discussion Starter · #16 ·
Awesome. Glad u found a combo that works! I'm on eibachs as well so i'm hoping to lose some more gap with my taller combo....
Discussion Starter · #18 ·
Thanks man. Your Jeep was one of the ones that inspired me to get the 22s.
*I remember you had some issues that you thought were caused by the 295s. Did changing tires solve everything or were there other factors?
Discussion Starter · #20 ·
Awesome. Good news for those with 295s. Thanks for the info.
1 - 20 of 20 Posts
