I bought this sub box from them also. Haven’t installed yet. But I went with a JL10W6.. it requires a little more room so I have to trim some metal in stock location(very minor amount) but will also fit in stock location behind the stock grill.
The JL10W6 should smash with proper set up and tuning
Their box design is great and quick turnaround..
Can’t wait to install mine and hear how you like yours..
Good luck
Its a nice enclosure for sure, but not sure id buy another one. After 2 months of use, the sub blew apart the baffles and started leaking air. I had to take the box back out and have the inside resined and then had it rhino lined to ensure no more leaks. In the end this turned out to be $550 enclosure. Honestly, Id just got with the JL Stealth box . Unless your looking to put a diff sub in there .
I have decided to upgrade my HK subwoofer in my 14 SRT. Everyone knows about the JL stealthbox but I believe I have found a better, and less expensive option. After researching online I found a place in Florida that makes a super nice, computer milled, epoxied, custom designed sub enclosure for the stock sub location. They can build it to fit a 10"or a 12" sub. I went with their recommendation of an audiomobile 2112 sub 2 ohm, but they will build it to whatever sub you want (that can fit and move in the the space). The audiomobile sub is specifically designed to function well in tight, low volume enclosures. Google "audiomobile 2112" to read up on the sub design. The company that makes the box is 'Audio Designs and Custom Graphics' in Jacksonville, FL. They shipped my sub/box to Wisconsin for 35 bucks. The Jeep's stock panel cover and sub speaker grill fit over their box so no need to worry about changing that up to fit a 12" woofer. I'm going with an LC2i tapped into the rear door speakers and a Rockford Fosgate Prime R500X1D (500w rms @ 2 ohm) mounted under the passenger seat above the battery. The remote bass knob will be mounted in the blank spot to the right of the terrain knob in the opposite side position of the launch button. I borrowed that photo from another poster here to illustrate the location, (thank you).
So here's the cost breakdown.
Custom sub box with premounted/wired audiomobile 2112 (2 ohm 500w rms)
614.00 shipped
Rockford Fosgate Prime R500X1D 500w rms 2 ohm amp.
107.00 shipped
LC2i 73.00
Pro installation with sound deadening material and tuning
300.00
So 1095.00 all in, pro installed, with quality components and tuned. This is the best bang for the buck and simplest install I've seen mentioned anywhere on jeep boards. And you get a 12" instead of the more expensive 10" from JL. I will have this set up installed this coming Saturday and I have no doubt it will be, shall we say, 'more than adequate' heh heh.
