Bc racing coilovers have a few questions - Cherokee SRT8 Forum
post #1 of 3 (permalink) Old 04-14-2019, 08:56 PM Thread Starter
Srt8_corey's Avatar
So recent jeep owner. Just started mooding it. Yesterday I installed my bc racing coilovers. Got them to a height I'm happy with especially with how bad the MI roads are. I have a few questions.
1. Has a anyone had any experience with these coilovers settling in and lowering more. With most of my other cars what you see is normally what you get.
2. How much is to gain from swapping over to BWoody sway bar links control arms and ext. I'm not tracking the car does anyone feel it's a necessity or just a recommendation.
3. Saved the best for last. Currently running maxed out shock and just the spring with no perc in the rear. Has anyone had theirs sit lower? Honestly expected a little more out of these. Not saying I would go much lower just curious.
Here is a pic of the current ride height. Thanks for reading and any response is always appreciated. Look forward to being a long time member and Jeep owner.
Srt8_corey is online now
post #2 of 3 (permalink) Old 04-15-2019, 12:12 PM
cmn1's Avatar
Sway bar links will firm up the wheel hop. Make sure you remove rear bump stops and metal perch.
Sent from my SM-G960U1 using Tapatalk
cmn1 is offline
post #3 of 3 (permalink) Old 04-15-2019, 01:05 PM Thread Starter
Srt8_corey's Avatar
Yea already removed the bump stops and perch. That was a fun experience. Kept bottoming them out and was like what the hell am I hitting on. Sure enough that was the issue.
Anyone near Oviedo, Florida have a WK1 with BC Racing coilovers? JSTBCUZ South / Southeast 0 10-04-2013 03:19 PM
BC Racing Coilovers - What Else Needed to Reduce Future Wear and Tear? MentorSRT8 WK1 Suspension / Driveline Discussion 8 09-28-2013 07:13 PM
Received my BC Racing Coilovers mcopare WK1 Suspension / Driveline Discussion 18 07-01-2012 03:58 PM
BC Racing Coilovers Cwh80 WK1 Suspension / Driveline Discussion 10 12-25-2011 03:40 PM
