sunroof scare . . . - Cherokee SRT8 Forum
post #1 of 10 (permalink) Old 03-14-2010, 10:23 AM Thread Starter
sunroof scare . . .
Last night, started up, and pushed the sunroof button -- only position that worked was the vent button, but it went up in discrete steps, like 1 2 3 4 5 (5 touches of the button) until it was fully open in the vent position -- and there it STUCK -- so I drove home, and thought, maybe if I turn off and restart the module will reset. No dice: went in and started looking for tech info on the sunroof (I had a module go bad on my 1st Magnum, so I know sh#t happens)
Anyway, after an hr decided to go out again, and just held the button down, and Lo and Behold, it closed -- back to normal (I think).
WTF???
6.1L '07 TORRED MSRT8 1/165 6.1L '10 SILVER Jeep GC SRT8
da BoMM is offline
post #2 of 10 (permalink) Old 03-14-2010, 10:42 AM
Administrator
Rambit's Avatar
There is a recallibration procedure for the LX's and I'm thinking it's the same for our Jeeps. Give this a try:
SUNROOF POSITION CALIBRATION
Press the power sunroof switch (Open, Closed, and Vent). If no movement occurs when either the open switch or closed switch is pressed, but the system does move when the vent button is pressed and held, the system is not calibrated. Perform the following procedure to position calibrate the power sunroof system.
1. Turn the ignition to the RUN position.
2. Press the vent button on the power sunroof switch and hold until the sunroof glass panel has moved to the full vent position and the motor movement has stopped for at least 1 second.
3. Press the close switch on the power sunroof switch and hold for a moment (at least 100ms) and release. The sunroof glass panel should continue travel to the full close position. If the sunroof glass panel does not return to the full close position, refer to the appropriate diagnostic information for full system diagnosis.
4. Verify proper system operation.
EXCESSIVE FORCE LIMITATION (EFL) CALIBRATION
NOTE: Verify the battery is in good condition prior to performing this procedure. Do not leave the vehicle on a battery charger while performing this procedure. If the voltage at the sunroof motor/module drops below 11 volts or exceeds 15 volts at anytime while this procedure is being performed, the Excessive Force Limitation (EFL) function will not be properly calibrated.
3. Press the close position on the power sunroof switch and release. The sunroof glass panel should continue
travel to the full closed position. This will be considered the first sunroof closed position in a series of four sunroof closes.
4. Press the vent button on the power sunroof switch and release. The sunroof glass panel should move to the full vent position. After the sunroof motor/module has stopped, press the close position on the power sunroof switch and release. The sunroof glass panel should continue travel to the full closed position. This will be considered the second sunroof closed position in a series of four sunroof closes.
5. Continue to move the sunroof glass to the “vent” then “closed” positions two more times so that the sunroof glass has moved to the closed position a total of four times starting with the first sunroof close in step 3.
6. Press the open position on the power sunroof switch and release. The sunroof glass panel should continue travel to the full open position.
7. Press the close position on the power sunroof switch and release. The sunroof glass panel should continue travel to the full closed position. This will be considered the first sunroof closed position in a series of five sunroof closes.
8. Press the open position on the power sunroof switch and release. The sunroof glass panel should move to the full open position. After the sunroof motor/module has stopped, press the close position on the power sunroof switch and release. The sunroof glass panel should continue travel to the full closed position. Continue to move the sunroof glass to the “open” then “closed” position four more times so that the sunroof glass has moved to the closed position a total of five times starting with the first sunroof close in step 7. Verify proper EFL calibration by placing a standard pencil at the front of the sunroof and then moving the sunroof to the full closed position. The sunroof should reverse direction upon contact without damage to the pencil.
Bernie
WK2 SRT8 Owners - Please post in the
thread!
2005 300C SRT8 - #72 of 252 (excl. 11 pilots) - #10 of 35 Canadian SRT8's built
2008 Harley Davidson FLSTF Fatboy - Vance & Hines Big Shots STGD with FuelPak tune.
2008 Jeep GC SRT8 - Custom Build/Custom Delivered by SRT - 1 of 1 in Canada
2012 JK Rubicon U - 2 1/2" lift, flares, Fox Shoks, Mickey Thompson Baha MTZ P3 35's, JW Speaker LED 8700 Evolution J Headlights etc...
Rambit is offline
post #3 of 10 (permalink) Old 03-28-2010, 08:31 AM
ASLEEPER's Avatar
Send a message via MSN to ASLEEPER
Has anyone else had issues with the sunroof doing what da BoMM's has done? I've had it happen a few times. I've tried the reset on Bernie's response which eventually fixes the problem until it happens next time.
The dlr has replaced the switch as it threw a code. My sunroof has done this again with the new switch & again the new switch has thrown a code so it's going to be replaced as well. I'm not totally convinced it's the switch at this point. Anyone else had this problem & if so has anyone got a fix? I had this happen on occasion with my '06 CSRT8 I owned previously.
'09 Brilliant Black, all options, dual Kicker Sub, ambient interior lighting kit, cabin filter, Escort 9500ix w/Stealth mirror cord, Blendmount mirror mount & ZR4 Shifters, Mopar PDA holder, Weathertech Mats w/SRT Logos, Mopar CAI, BT Catch Can w/underhood dress up kit, Jeep rear cargo tray, HID fogs w/functioning rear fogs, shorty 8" black antenna, 6.1 Hemi Badges (fenders), SRT8 badges (doors), Intune & Johan Tune
ASLEEPER is offline
post #4 of 10 (permalink) Old 03-28-2010, 10:17 AM
Crookster777's Avatar
Had the same exact problem. I couldnt close it, so I parked it for the evening and came back in the morning and pressed the button and it closed. Never happened again though.
-Joe-
2016 B5 Blue Dodge Charger Hellcat
SOLD: 2015 Jeep Grand Cherokee SRT8
SOLD: 2010 Jeep Grand Cherokee SRT8
Crookster777 is offline
post #5 of 10 (permalink) Old 03-28-2010, 10:50 AM
Just trying to go Fast
TheBRICK's Avatar
I had my regulators replaced in my front windows and sunroof. Still get intermittant problems. Typical Jeep Electrical Gremlins!
2007 Jeep GCSRT Turbo [email protected]
2018 Trackhawk TriCoat Ivory Intake and Solo cat back
2015 Hellcat Charger 770rwhp gone and forgotten
TheBRICK is offline
post #6 of 10 (permalink) Old 03-28-2010, 07:07 PM Thread Starter
update -- just an fyi --
since the "incident" on 3/13 I've had no problems --
sunroof works normally -- just was awkward at the time, and
has me wondering when it might happen again . . .
da BoMM is offline
post #7 of 10 (permalink) Old 03-30-2010, 10:14 AM
JEEPYOU's Avatar
Had it happen to me too... about a month after getting her. Same situation, went inside after it stopped working (stuck in opened "vent" position) and an hour later when I tried it again it worked.
Could this be just a 2010 thing? da, what year is your rig?
JEEPYOU is offline
post #8 of 10 (permalink) Old 03-30-2010, 10:47 AM
Wow thanks for the calibration instructions! About 2 out of 10 closes the sunroof will almost close, then open all the way (pinch feature). I took it to the dealer on two occasions and they couldn't replicate it. Now my warranty is up.
santov is offline
post #9 of 10 (permalink) Old 03-31-2010, 09:31 PM Thread Starter
mines a 2010 too -- so far, only the key fobs (intermittent) and this sunroof incident, are the only issues: very minor in the big scheme
da BoMM is offline
post #10 of 10 (permalink) Old 04-24-2019, 05:42 AM
Yes, I know, bumping up an old thread, but this is my exact problem.
Got in the jeep this morning and the sunroof wouldn't close. Only button that worked was the center vent button. Well, now the sunroof is stuck in the vent position and none of the buttons do anything. I've seen the 'Reset procedure' described, but it talks about pressing the buttons and having the sunroof move during each part of the reset. MINE WON'T MOVE, regardless of which of the 3 buttons I push.
Any suggestions??
Thanks
edfiero is offline
rattle from sunroof pnut WK1 Troubleshooting / Problems Discussion / Dealer Service 15 03-23-2011 09:18 PM
How to scare the heck out of your wife. TheBRICK Off-Topic Discussion 11 09-16-2009 02:00 AM
Had a scare with my son CentralTexHemi Off-Topic Discussion 25 06-06-2009 07:40 AM
windows/sunroof maxxjeep WK1 Troubleshooting / Problems Discussion / Dealer Service 3 07-23-2007 11:28 PM
Sunroof ? Thumpn WK1 SRT8 General Discussion 6 03-23-2007 08:01 PM
