Another Overheating Issue - Cherokee SRT8 Forum
post #1 of 13 (permalink) Old 04-23-2019, 03:46 PM Thread Starter
wolf's Avatar
Hey Fellas. Just need a little help. I have read damn near every thread on this overheating issue. In Georgia and high is maybe 80 degrees. Yesterday the temp gauge went all the way into the red sitting at idle and did the same today. Luckily I was near a restaurant and the daughter and I just went and had dinner while the jeep cooled down. I have noticed that I have been getting some bearing noise coming from the engine (sounds like damn chipmunks). Put in a new 180 thermostat, burped, fan relays and still rising temps. I'm assuming its the water pump bc of the bearing noise. Any help would be GREAT!!!
Thanks!
2010 JEEP SRT8
CAM **MEAN STREET HEADS**JOHAN TUNED**275/315 nitto motivos**catch can**t-180 stat**bwoody 4 intake**hid fogs 6k**bwoody shorty antenna**corsa exhaust / resonator delete / qtp cutouts**kooks longtubes w/catted mid-pipe
wolf is offline
post #2 of 13 (permalink) Old 04-23-2019, 04:04 PM
viking757's Avatar
Take the belt off and feel for play on the water pump
viking757 is offline
post #3 of 13 (permalink) Old 04-23-2019, 04:39 PM Thread Starter
wolf's Avatar
Am I checking to see if the whole assembly is loose?
wolf is offline
post #4 of 13 (permalink) Old 04-23-2019, 06:14 PM Thread Starter
wolf's Avatar
So the black bearing has a little play. I guess hence the the chirping chipmunk I hear. Is that enough to make the water pump go bad? The temp gauge was completely touching 245 degrees at one point. Of course, once you start driving the temp goes down. Thoughts?
wolf is offline
post #5 of 13 (permalink) Old 04-23-2019, 07:05 PM
BJB
"guy with the crazy Jeep"
BJB's Avatar
Bad water pump...
Brian
BJB is offline
The Following User Says Thank You to BJB For This Useful Post:
Passmg2 (04-23-2019)
post #6 of 13 (permalink) Old 04-23-2019, 07:34 PM
Thread Derailer
Passmg2's Avatar
Bad, bad water pump...go to your room!
Passmg2 is offline
post #7 of 13 (permalink) Old 04-23-2019, 11:52 PM
gregmanz's Avatar
You mention fan relays but are the fans running when at temp? The only thing that stops being functional once driving would be fans, and you mention the temp goes down once driving
gregmanz is online now
post #8 of 13 (permalink) Old 04-24-2019, 12:44 PM
viking757's Avatar
Good point.
Was the thermostat checked as well? Nonetheless the pump shouldn’t have any play.
post #9 of 13 (permalink) Old 04-24-2019, 01:42 PM
gregmanz's Avatar
Good point.
He put In a 180 he says but from what I’ve seen they are issue prone alone.
The water pump shouldn’t have play though but I don’t believe it to be the main over heating issue. Also I would think the thermostat isn’t it, it would cause over heating regardless of moving or not. The radiator is doing its job at speed
post #10 of 13 (permalink) Old 04-24-2019, 05:36 PM Thread Starter
wolf's Avatar
Thanks for all the feedback fellas. These cooling issues drive me crazy. I've had bad thermostats in 100 degree southern weather and the temps at idle have only gotten to 220. Now we have 80 degree Ga weather and the damn thing hits 245. Even if it was just the thermostat, I've never had a temp spike like that but once years ago driving down the highway and the temp wouldn't lower (cant remember the solution). Hopefully its the water pump, ordered from HHP and will be installed along with a paramount valvebody. In regards to the fan relays, the fans were running at temp. I swapped them along with the thermostat, trying to diagnose with the cheaper items first. Damn chrysler wants to charge me $1000 for pump and install. I got a local performance shop, Injected Engineering, doing the installs next week for less than the chrysler cost.
wolf is offline
Overheating..., then not overheating.. bigwil WK2 SRT8 Troubleshooting / Problems Discussion / Dealer Service 9 11-27-2015 03:00 PM
Overheating issue...yup another story Aco275RGR WK1 SRT8 General Discussion 7 04-02-2015 11:49 PM
Yup another Overheating issue... Dante_RWerkz WK1 Troubleshooting / Problems Discussion / Dealer Service 1 09-16-2013 04:59 AM
2006 Overheating Issue pdowns WK1 Troubleshooting / Problems Discussion / Dealer Service 12 07-30-2010 07:54 PM
Overheating issue is fixed!! Kinda scarry too. TheBRICK WK1 SRT8 General Discussion 17 06-24-2009 08:29 PM
