2 bar map from hhp issues - Cherokee SRT8 Forum
post #1 of 20 (permalink) Old 05-08-2019, 08:40 PM Thread Starter
I purchased a 2 bar map part #050332224ab for my 2007, when i plug it in i immediately get a low baro cel and the tps red lightning bolt, the instant i unplug it both issues go away, this happens with either 1 bar or 2 bar tune from diablotoona so my first assumption is a pinout issue as the connectors are 180° different as far as the alignment ridge, has anyone had this issue? The part number crosses to a 2014 ish dodge but is the pinout different on a 2007 jeep?
Thanks for your help guys!
CrazyBob is offline
post #2 of 20 (permalink) Old 05-08-2019, 08:52 PM
viking757's Avatar
Another Johan failure
viking757 is online now
post #3 of 20 (permalink) Old 05-09-2019, 05:52 PM Thread Starter
You don't like johans work?
CrazyBob is offline
post #4 of 20 (permalink) Old 05-09-2019, 08:49 PM
gregmanz's Avatar
He most certainly doesn’t
gregmanz is offline
post #5 of 20 (permalink) Old 05-09-2019, 09:09 PM Thread Starter
I guess I don't know the back story on this.
CrazyBob is offline
post #6 of 20 (permalink) Old 05-10-2019, 04:56 AM
viking757's Avatar
No backstory just have been on the forum and have seen continuous issues with his tuning.
post #7 of 20 (permalink) Old 05-10-2019, 09:34 AM
Had this exact same issue with Johan tuning my buddies whipple Durango. Ended up using the stock sensor but now the engine is built and we are about to fire it up. He blamed it on diablo T1000 not playing nice. Now have tune loaded with T2 module but waiting on some fuel fittings to find out if issue will be resolved. Guessing it’s not the SW being your having same problem with HP
Hellcat87 is offline
post #8 of 20 (permalink) Old 05-10-2019, 06:58 PM Thread Starter
Map reading is 25 inhg spot on but baro reading is 32 inhg,
I'm hoping that the cmr program allows to custom scaling to get baro to 25 inhg, i know i can do it with my diesel tuning software so i don't think there would be an issue with cmr software allowing it as well, just for reference my digital barometer shows 24.48 inhg.
CrazyBob is offline
post #9 of 20 (permalink) Old 05-10-2019, 06:59 PM Thread Starter
Do you know if cmr software allows separate baro scaling?
CrazyBob is offline
post #10 of 20 (permalink) Old 05-10-2019, 07:08 PM
We were seeing both MAP and Baro readings maxed out to like negative 99 or something so problem may be a little different.
I imagine CMR allows for scaling like the HP tuners I’m used to. But it’s probably much more complicated
HHP/BES Stage 1 or HHP/BES Stage 2 pjsmokin WK1 Engine Performance/Superchargers/Turbos/Nitrous 21 08-10-2013 01:13 PM
waht do u recommended hhp stage 2 cam or hhp stage 2 R cam new dude WK1 SRT8 General Discussion 2 05-25-2012 06:17 PM
3d Mock Up Roo Bar, Nudge Bar, Bull Bar Chykan WK1 Interior/Exterior Visual Modifications 22 11-30-2011 12:05 PM
