Need engine harness connector identification Help - Cherokee SRT8 Forum
post #1 of 4 (permalink) Old 05-12-2019, 07:19 PM Thread Starter
bigblack315's Avatar
Just dropped in a new engine and got a engine harness from a friend it’s missing some of the connectors I need help identifying what Connectors i need to put back on
does anyone have there engine harness out that can send me a picture of the missing connectors???
2A6E3BC3-1F88-4868-A0DA-4F4B8F3B8910_1557710331324.jpeg   7FB5837D-25D6-4E93-A462-FDEC2D8F7E03_1557710349254.jpeg
bigblack315 is offline
post #2 of 4 (permalink) Old 05-14-2019, 02:28 AM
gspfunk's Avatar
2nd pic goes to the trans connector and 4 O2 sensors. Looks like youíre missing 2 of the O2ís.
The 1st pic is hard to make out, but it looks like the lower passenger side of the engine harness. If thatís correct, itíll have the knock sensor (pictured in foil sleeve), crank position sensor, alternator ring (thicker cable), alt. connector, IAT sensor, oil pressure (or temp?, canít remember), and speed density sensor.
I just pulled the trans out of mine, so I can get under there tomorrow and double check if you know for sure. Iíll look back through my pics from when I pulled the engine too.
gspfunk is offline
post #3 of 4 (permalink) Old 05-14-2019, 02:30 AM
gspfunk's Avatar
Also, be sure you get the O2ís on the right plugs or it will throw codes and run wonky.
gspfunk is offline
post #4 of 4 (permalink) Old 05-14-2019, 04:41 AM Thread Starter
Thank you I got it all fixed up I appreciate the help
The Following User Says Thank You to bigblack315 For This Useful Post:
gspfunk (05-15-2019)
Part Identification - Headlight Covers Jasonlmarsh WK1 SRT8 General Discussion 2 11-04-2013 11:47 AM
Need OB2 connector pinout!!!!!! SRT8-DOUGLAS SR WK1 Troubleshooting / Problems Discussion / Dealer Service 0 02-10-2013 04:21 PM
Need OB2 connector pinout!!!!!! SRT8-DOUGLAS SR WK1 Troubleshooting / Problems Discussion / Dealer Service 2 02-10-2013 04:08 PM
what connector is used to connect harness to fuel injector? SRT8-DOUGLAS SR WK1 SRT8 General Discussion 1 10-15-2012 08:36 AM
Help!!! Need connector for the Integrated Power Module (2005 - 2010) BJB WK1 Troubleshooting / Problems Discussion / Dealer Service 25 04-13-2012 10:19 AM
