Traction Control code only when in boost - Cherokee SRT8 Forum
WK2 SRT8 Engine Performance/Superchargers/Turbos/Nitrous Discuss engine performance enhancing modifications, superchargers & turbo applications specific to the WK2 SRT8 here.
 2Likes
  • 1 Post By viking757
  • 1 Post By Poorboy
post #1 of 7 (permalink) Old 05-01-2019, 08:41 AM Thread Starter
Ok, maybe I need to take it back to the tuner. I get a code for the sensor on the brake booster (check valve), which sets the traction control light only, every time I put it in boost. I am guessing the computer doesn't like to see pressure at the sensor. Has anyone else ran into this? It resets itself every time I restart it. Thanks.
2014 Jeep SRT
2015 Street Glide special
1976 Charger 19' jet boat
Poorboy is offline
post #2 of 7 (permalink) Old 05-02-2019, 03:13 PM
BJB
"guy with the crazy Jeep"
BJB's Avatar
Who is tuning?
Brian
BJB is offline
post #3 of 7 (permalink) Old 05-02-2019, 04:07 PM
viking757's Avatar
Originally Posted by BJB View Post
Who is tuning?
His friend at some shop
Poorboy likes this.
viking757 is online now
post #4 of 7 (permalink) Old 05-14-2019, 01:27 PM Thread Starter
found out its not the blower- At the dealer now, they think it is a module, it does it under high vacuum.....like when you let off after boost lol.
Poorboy is offline
post #5 of 7 (permalink) Old 05-14-2019, 04:25 PM
viking757's Avatar
That doesn’t make sense since the highest amount of vacuum normally occurs at idle/when the throttle blade is closed.
post #6 of 7 (permalink) Old 05-16-2019, 03:38 PM Thread Starter
Ok maybe I wasn't explaining myself right. When you are in boost...WOT you see a high amount of vacuum when you let off and coast. I figured this out when is set the light going down hill towing with my foot off the gas.
Anyhow dealer found it to be a bad booster and I also got a battery light which turned out to be a bad alternator. Thankfully extended warranty covered it all.
BTW I just towed my boat 6 hours each way through mountains and averaged 17.6 mph, I am pretty happy about that.
viking757 likes this.
Poorboy is offline
post #7 of 7 (permalink) Old 05-16-2019, 04:33 PM
viking757's Avatar
Great news and battery/voltage issues will cause some odd things to happen.
Electronic throttle control / traction control cjwhitelaw WK1 Troubleshooting / Problems Discussion / Dealer Service 2 12-21-2014 07:13 PM
Traction, traction, traction... wink Track Talk 14 09-27-2013 10:47 PM
Supercharged SRT8s...Where did you tie in your boost gauge? Which vacuum/boost line jmrice WK1 Engine Performance/Superchargers/Turbos/Nitrous 27 06-22-2013 10:05 AM
Traction control and Boost Grip Grip WK1 General Performance Discussion 7 10-13-2009 06:37 AM
Neat Vid, blown boost tube at moderate boost levels navyavi469 WK1 General Performance Discussion 19 12-14-2008 10:46 AM
