Whipple knock help - Cherokee SRT8 Forum
WK2 SRT8 Engine Performance/Superchargers/Turbos/Nitrous Discuss engine performance enhancing modifications, superchargers & turbo applications specific to the WK2 SRT8 here.
 5Likes
post #1 of 22 (permalink) Old 10-11-2017, 08:23 PM Thread Starter
Whipple knock help
Hey guys,
I recently installed a whipple kit on a stock motor. Im running about 7psi at 5000 ft elevation. Johan is doing the tuning and everything was going great until the last few days. I recently started to get some heavy low end knock. The last log shows 8 deg ST and 2 deg LT at 23% throttle at 1500 rpm then 6 deg ST and 6.5 deg LG at 65% throttle and 3900 rpms. If i can get past the low end knock WOT is perfect no knock 10.8 AFR threw redline.
Since the problem started I have reverted back to some old tune revisions that had no previous issues, completely drained the fuel in the tank and refilled with shell 91 octane (from the same station I had success with earlier), and re-torqued every exhaust bolt i could find. By hand I can find any metal to metal contact when moving the exhaust.
Any ideas?
2007 JGC SRT8 Paramount trans wavetrac, GTX4294R Turbo Sold
lilsmokey is offline
post #2 of 22 (permalink) Old 10-11-2017, 08:26 PM Thread Starter
Another note, prior to the knock issue I installed a catch can. This is how I have it installed. Did I do something wrong here?
post #3 of 22 (permalink) Old 10-12-2017, 12:57 PM
Hey Smokey, can't help with the catch can... but the work that you went through to "revert back" seems really extensive... except that you left the 1 piece of hardware in place that you changed.
Pull the catch can and see what happens... check the hose "post" CC for excessive amounts of oil.
2016 Charger Hellcat
Jack_Toepfer is offline
post #4 of 22 (permalink) Old 10-12-2017, 01:38 PM Thread Starter
Thanks for the reply, I didnt go back to stock, I installed some of the early tunes that Johan sent that didnt have the problem the first go around but did when I reverted back.
The hose that runs from the CC to the intake snout is perfectly clean. The CC seems to be doing a great job.
post #5 of 22 (permalink) Old 10-12-2017, 05:07 PM
viking757's Avatar
Are you in part throttle boost when you get the knock? What is your manifold pressure at the time the knock event occurs? What is the AFR?
viking757 is offline
post #6 of 22 (permalink) Old 10-12-2017, 07:31 PM Thread Starter
In all cases less than 2 psi, AFR between 13-15. Its looking like rattling exhaust valves are the problem. I zip tied open and had a few miles with no problems until the ties melted.
post #7 of 22 (permalink) Old 10-12-2017, 07:50 PM
viking757's Avatar
Great work!!!!
post #8 of 22 (permalink) Old 10-12-2017, 07:56 PM Thread Starter
Its crazy how sensitive the knock sensors are!
Thanks for the replies guys
post #9 of 22 (permalink) Old 10-13-2017, 07:11 AM
viking757's Avatar
That sensitivity can be adjusted but proceed with caution
post #10 of 22 (permalink) Old 10-22-2017, 07:47 PM Thread Starter
Well the knock is 100% gone but now I have what feels like TC shutter. It only happens under 2000 rpm and gets progressively worse with throttle input. (Shakes more with 50% throttle than 15% throttle). The strange thing to me is the exhaust note seems to change almost like MDS kicking in and a similar shake.
I havent been able to get a good launch, off idle, brake torque, launch control all fall on their face before coming into power.
Johan cant find anything in the tune that he doesnt like.
Any hail marys?
knock knock, who's there? Freeksen WK1 Tuning/CMR/Dyno/DataLogging/Gauges 17 02-23-2017 09:36 AM
ST and LT Knock rconner WK1 SRT8 General Discussion 6 05-28-2010 10:12 AM
Real Knock/False Knock ajharman WK1 Tuning/CMR/Dyno/DataLogging/Gauges 18 08-13-2009 10:07 PM
Knock knock...What's wrong with this picture? tainui WK1 Troubleshooting / Problems Discussion / Dealer Service 3 10-31-2007 09:42 PM
A knock when I first take off RTBIII WK1 SRT8 General Discussion 3 10-29-2006 08:36 AM
