Ticking sound from engine - Cherokee SRT8 Forum
post #1 of 6 (permalink) Old 05-11-2019, 05:34 PM Thread Starter
Majeed_'s Avatar
Hey guys I’m new to the forum! So I have a Jeep Grand Cherokee SRT 2015, and recently I noticed a slight ticking sound coming from the engine, the sound could be heard from inside the car but only if the windows are open and I’m next to a wall or something to reflect the sound.
Once I opened the hood I noticed the sound coming from the right side of the engine (if facing the front of the car).
I’m not really sure what’s causing the sound, I was told it could be coming from the valves or the fuel injectors!
Here’s a link to the video with the sound:
Thanks
Majeed_ is offline
post #2 of 6 (permalink) Old 05-11-2019, 05:37 PM Thread Starter
Majeed_'s Avatar
And by the way the sound mostly comes when the engine is warmed up. And when the sound comes it stays for a minute or so then stops, but comes back.
3 days ago I added a valve lubricant to the oil and a fuel cleaner but the sound still prevails.
Thanks again!l]
Majeed_ is offline
post #3 of 6 (permalink) Old 05-11-2019, 05:43 PM Thread Starter
Majeed_'s Avatar
Hey guys! any idea what the sound could be coming from?
Majeed_ is offline
post #4 of 6 (permalink) Old 05-14-2019, 01:50 PM
My guess is the lifters. IIRC sounds close to mine, but sometimes the recorded audio could be different than in person(like exhaust clips).
Mine started making a noise at 72k miles.
Dealer replaced them. Can't tell you what it cost cause it was still under warranty. Took them a day to do.
Truck still ran fine, or at least not a noticeable drop in power and had no codes.
John813 is online now
post #5 of 6 (permalink) Old 05-16-2019, 06:11 PM
SRT8-X's Avatar
I just picked mine up from the dealer last week and on the way home, loss of power (not significant but noticeable), rich smelling exhaust, the TICK and eventually a P0303 #3 cylinder misfire code. I've cleared it a few times, comes back on some quickly and others later. Performance does not seem to be altered much now. I checked the coil pack, switched with #1 and still the same code. Checked for spark and looked at all harnesses for the injectors, coil packs, etc.
The tick is the part that bothers me as it sounded like valvetrain chatter or engine noise. Then I dug deeper. It appears the tick is coming from (and vibrating profusely) the Purge Valve Solenoid behind the left bank (drivers side) which then echos off the aluminum shielding and then under the SRT. I'm going to change this $25 part out before assuming it's internal issues or before spending $500 on plugs and coil packs. I hear DUI makes a great set dyno proven for 12WHP for the SRT so I don't mind spending a bit there. I'm at 87k, not wanting to hijack the thread but any thoughts regarding the P0303 situation and these symptoms would be appreciated. I'm past 5-years since registered so the powertrain warranty is up.
SRT8-X
'14 Bright White WK2 SRT
(h/k SRT High Performance Audio, Panoramic Sunroof, CAI, SRT Black Center Caps, JL Audio Stealthbox, HD750/1, AudioControl LC2i)
SOLD '13 Alpine Edition WK2 SRT8 (Borla Axle Back)
SRT8-X is online now
post #6 of 6 (permalink) Old 05-22-2019, 02:20 PM
ibpnyc's Avatar
Going they the same thing with a P0302 error. I have my situation posted here.
https://r.tapatalk.com/shareLink?url...2&share_type=t
Need help. cylinders misfiring
Sent from my Pixel 2 XL using Tapatalk
Creative Director | Senior Color/Production Specialist
2012 JGC SRT8 | Black/Black | Stock Setup
“Spread Love It's the Brooklyn Way!” – Notorious B.I.G.
ibpnyc is online now
ticking sound when accelerating dennisr WK1 Troubleshooting / Problems Discussion / Dealer Service 1 10-22-2014 02:32 PM
2012 srt 8 ticking sound wikkid WK2 SRT8 Troubleshooting / Problems Discussion / Dealer Service 2 05-26-2014 08:28 PM
ticking/crackling sound when starting jeep Mikea123 WK1 Troubleshooting / Problems Discussion / Dealer Service 4 05-24-2014 10:58 AM
Ticking sound when starting jeep BYT86GN WK1 Troubleshooting / Problems Discussion / Dealer Service 15 03-16-2012 08:43 AM
What is that ticking sound from the engine. jeepmystery WK1 Troubleshooting / Problems Discussion / Dealer Service 15 02-27-2010 12:48 PM
