New WK2 Owner - Dash lights up! ABS, Serv 4wd, ACC, Park sense failure - Cherokee SRT8 Forum
post #1 of 5 (permalink) Old 02-17-2019, 02:18 PM Thread Starter
OK so a few weeks ago my wife and I bought a used 2014 WK2. I was hesitant to buy it considering the issues we had with our last WK1, but the the wife really wanted it. So yesterday it started acting up by giving us multiple faults. Just my luck. Here is what the faults are that it displays at startup:
ABS Failure
Park Assist failure
Blind spot failure
ACC failure
Service 4wd system - vehicle operates in 2wd only now
So basically all the systems stopped working and of course its snowing out and my wife needs to get kids up and down the mountain and now with only 2wd. Sounds like a wiring issue to me or maybe something got some moisture in it due to the snow we have been getting. Did a quick inspection under the hood and didn't find anything loose or unusual. All grounds seems tight as well. I plugged in with my pocket code reader, but was unable to see any fault codes. I was going to start by washing it really well to get the snow and ice off of it then do a visual under the chassis to see if I can find something, but in the meantime was going to pull the negative battery cable for a bit and see if I can reset the system. Any issues with disconnecting the battery? I know some cars will literally lock you out of functions and system once the battery has been disconnected and require a dealer reset. Our Chrysler dealer is horrible and I will avoid taking anything to them at all costs. (They had our WK1 for 7 weeks over a clock spring in the steering column.....worthless)
Well if anyone has seen this before or has any other ideas for me let me know. When I did some searching it seems i'm not the only one that has seen this issue when it rains or snows. Thanks!
Switch is offline
post #2 of 5 (permalink) Old 02-20-2019, 05:39 AM Thread Starter
Update - Still haven't had a chance to get it in the garage yet, but after having the wife wash the car the warnings reset and went away. They have come on and offer intermittently the last few days so I'm fairly certain I am chasing a loose connection or lose wheel speed sensor. I'll add to the thread when I hunt down the issue and hopefully this helps someone in the future with this issue.
Switch is offline
post #3 of 5 (permalink) Old 02-24-2019, 10:10 AM
Lokeybrandon's Avatar
Had a similar issue three days after purchasing my ‘12. It was the front sensor I forget the name of it but it was the sensor that handles the adaptive cruise. It set off tons of issues like what you mentioned. They replaced it for free since I had just purchased the car. For which I am lucky. I’ve only had to spring for a thermostat ps pump and a rack and pinion since purchase ... smh.
Lokeybrandon is offline
post #4 of 5 (permalink) Old 02-28-2019, 07:40 AM Thread Starter
Ya, the dealer I bought it from is worthless and won't do anything (curse of living in the northwest. All the dealers in the region are horrible). Got it into a local shop that has a better scan tool than mine and sure enough one of the rear speed sensors failed. Will confirm that that clears everything up today when the part comes in, but I bet she will be working fine. Now I just have to find the mystery coolant leak that no one can find either lol.
Switch is offline
post #5 of 5 (permalink) Old 04-13-2019, 07:04 PM
Any update on your coolant leak?
Service 4wd and ACC/FCW ? 2014 srt SrtTONY1320 WK2 SRT8 Troubleshooting / Problems Discussion / Dealer Service 14 10-26-2018 11:01 AM
Lane Sense Plus versus Lane Sense Shark WK2 SRT8 General Discussion 4 09-19-2016 01:06 PM
Help - Service 4WD, ABS Light, Taction Control Light, FCW Disabled, Service Park Mongoose9400 WK2 SRT8 Troubleshooting / Problems Discussion / Dealer Service 9 09-14-2013 09:12 PM
HELP! Service 4WD system, ABS, ESP and TCM lights on the dash! carfreak493 WK1 Troubleshooting / Problems Discussion / Dealer Service 5 08-25-2013 09:12 PM
Trouble Shifting, Service 4WD System & ABS, ESP/BAS, Traction Control Lights on SML9284 WK1 Troubleshooting / Problems Discussion / Dealer Service 15 12-08-2011 11:11 PM
