Any SRT grille emblems? - Cherokee SRT8 Forum
post #1 of 7 (permalink) Old 05-12-2019, 05:24 PM Thread Starter
Anyone running any SRT grille emblems? Looks like the charger ones are too big to fit in the grille.
Any suggestions? Just found it odd that FCA didn't identify the vehicle from the front with a front emblem (or the sides, for that matter).
Curious if anyone has done any modification to get one to fit.
srtfrank is offline
post #2 of 7 (permalink) Old 05-12-2019, 08:09 PM
travis91's Avatar
I have one on mine. Cant tell you where it was purchased from or what it is off of but maybe someone can. Quality looks real good Click image for larger version
travis91 is offline
post #3 of 7 (permalink) Old 05-12-2019, 10:00 PM
I got one off of Amazon. I attached it with double sided tape and itís still holding strong for over 2 years. You could find the factory rear SRT badge, but itís hard to apply because each letter is separate. Mine was an older SRT grill badge from the Charger/Challenger which is a one piece badge. I cut off the holding tabs and used double sided tape...
pnut is offline
post #4 of 7 (permalink) Old 05-13-2019, 01:03 PM
Ditto as to amazon. But I used the glue Goop.
Redwings1 is online now
post #5 of 7 (permalink) Old 05-13-2019, 02:48 PM
Hemi Cruiser's Avatar
I put the SRT letters I took off the tailgate onto a piece of aluminum flat I painted black
Hemi Cruiser is offline
post #6 of 7 (permalink) Old 05-14-2019, 08:15 AM
CuJo's Avatar
I ordered the one from the Challenger and use it on my WK1. I've also seen a bunch of people using this: https://x-lume.com/products/srt-illu...adge-for-jeeps
CuJo is online now
post #7 of 7 (permalink) Old 05-14-2019, 03:36 PM
djjasond's Avatar
I also did the same but ordered the prevalent one on eBay if you search for SRT grill emblem. It has two bolts that fit between the honeycomb pattern in the lower grill. Simply tighten with the provided washer and nut.
I did cut the bolts down because they were several inches long and didn't need anywhere near that much to clear the grill. In terms of access behind the grill, the little plastic shroud at the lower center of the grill pops right out. I'll include a picture of the back of it so you can see the clips. My teenage daughter was then able to slide her hand behind the grill to tighten the nuts without removing the bumper. Really easy upgrade.
2018 Jeep Grand Cherokee Trackhawk
2014 Jeep Grand Cherokee SRT (sold)
2010 Jeep Grand Cherokee SRT8 (sold)
2007 Jeep Grand Cherokee SRT8 (sold)
djjasond is offline
One of the 7 grille inserts broke. Dealer tells me I need entire grille! KamilSRT8 WK1 Interior/Exterior Visual Modifications 15 03-28-2012 06:14 PM
Links to Grille Srt-8 Emblems?? PETERSRT-8/10 WK1 Interior/Exterior Visual Modifications 6 02-28-2009 05:07 PM
how to remove stock grille/stock grille inserts Captain McFunk WK1 Interior/Exterior Visual Modifications 8 02-04-2009 04:29 PM
