Guys,
Have a 'different' problem here. I have HID fogs in my ride and they were working really well before. No relay, just plug and play into factory harness.
So, I wanted to use them today and when I pulled the stalk to turn them on, the green symbol on the dash did not come on and the fogs remained off.
I checked the fuse #15 in the engine bay (box closest to the front of the car) as per the manual and all the 20 amp fuses were ok.
When I try to turn the fog lamps on, I do not hear any relays clicking.
IS THERE ANOTHER fuse inside the car under the dash that controls the module that turns the fog lamps on and off??? IF so, what is it called and what fuse should I check for this?
All my other lights works fine. Just the FOGS are not working.
Anyone have any ideas on how to fix this?
Could it be my HID ballasts? How do I test this if it is the ballast?
Thanks
Thanks
