Can someone help me find a backup light conversion kit for backup LEDS? If there is a replacement taillight assembly with LEDs, that would be even better. Mainly, I'd want to change out the backup lights. I noticed that TRAINER had an LED kit installed on his GC, but I can't locate it on the web. Thanks!
Also, I noticed people do the Xenon conversion for Fog's on our trucks. Which kit is that? Is it a specific fog kit? The Leads would have to be pretty long to reach that far down, wouldnt they?
You can buy Xenon & LED bulbs that replace your exhisting bulbs(LED signals require resistors). The HID setup would require some mod(so I've read), do a search you may find other info.
Got all my LED stuff from here...Been in 9 months now, no problems. If you do with turn signals you will need resistors. Scroll down through Light Towers and also read info on resistors regarding fast flash. Easy install, look good.
Just so you know the 06 taillights dont work with the 07's because they use a different connection system for the bulbs- also the 07's use 2 bulbs and the 06's use 3
scroll down....you will need the 6 ohm....$6.99 or $8.99 depending if you are only go do the rears, or fronts and rears. They are an easy install. After tapping in just drop them down in the opening under tail lamp. Plenty of air circulation no heat issues.
when i finally get an SRT8, my first order of business will be working on a full LED array for the taillights. my current car has full LED taillights and the difference between regular bulbs and even between those tower LED bulbs is night and day. below are pics of what mine look like now and something like what i might do for the SRT8
He is correct, but the only thing i disagree on is dropping them down under the lights, If they come in contact with any plastic or wires they will melt them instantly. I mounted mine under the rear bumper (lights) on the body frame and used hi temp silicone under and around it after I zipped them into the frame.
That's deffinitly not cool. I didn't buy those lights, just posted the link. I'm waiting for a better looking LED setup. But, you mentioned heating the lenses. Did that easily remoove the clear lense? I've got other ideas.
I like this: http://www.srt8oc.com/forums/showthread.php?t=3914
The backup bulbs ont he 2007 SRT-8's are standard 194 bulbs, believe it or not. The very same bulb that is under the dash and in the rear overhead lighting by the handles.
I wish I could find a super bright replacement for that, it would make backing up much nicer while using the camera. I wish someone made compatible halogens or a SUPER bright LED.
You can suppliment your backup bulb with the rear fog lights by connecting them to the tow harness. These bulbs are 1156. There are several LED options for these that I have found. The standard 1156 rear fogs adds to the brake light and backup light output, but I still would like more light myself. So I'm looking also...
will one of these work or do i hafto absolutly cut the wire and wich led most people go with cuz there are many that can fit 3157 also wich color white or red for tail lights????
Forget LED's and do HID Back Ups...with the rear camera they are rediculous...I did the slim Philips for Hi/Lows/Fogs/ and Back ups in 6000k and believe me it wasn't cheap but people are on it and it sure helps out with my super dark tint fetish!!! I get more questions about the rear HIDS than anything else on the truck hands down!!!
HALLSTAR TINT...
