so i got a flat tire thursday morning when i went out to my car. i filled it up with air and it held air solid till today. i washed the car and put it in the garage, took the rear drives side tire off to see what i could find and i found a pretty good slice in the center of the tread. it was pissing air and i could hear it. i took it up to the tire place to see if they could plug it and they found another hole in the sidewall that they said they could not fix. i took a ride up to check it out to see if they were just trying to pull my leg, sure enough there was a good gash in the sidewall also.
I really want to ditch the crapyears and go with something else but i have to drive to Maryland tomorrow so i dont have time to run around and see what else i can run so i told them to put on another GY for a cheap 390 dollar. 460 after mounting and all that crap. i see i can pick one up off tirerack for 275, but again im in a big rush.
are any of you guys running GY's in the front and another brand in the rear?
I was thinking of putting something good in the rear now and then changing out the fronts in the summer.
thoughts?
thoughts?
