Alright Guys, I was wondering a couple of things and hopefully a lot of you guys will chime in.
Here goes, and this is for Street Tires Only. What tire pressures are you running in the front and rear that give you your best 60ft and if possible you can give the street tires you are using as well and whether these are cold or hot tire pressures as tire pressures can change once the tires are driven on and warmed up. The answer should look something like this:-
Nitto NT05 Tires; Front 36 PSI, Rear 32 PSI COLD; 1.6 60ft
