well, i am trying to get the interior LEDs kit that Medic helped put togather, but i dont know if all the lights will fit for an import model.
knowing that the OEM reverse light for an import '08 model is not the same as the OEM '08 reverse light for the US model, so i am guessing may some or even all the interior lights be different too.
anyone has pics of the '08 OEM interior LEDs of the US model?
i would like to compare them with mine (import model SRT8)
for example i tried to check and see the OEM license plate lights and see if the lights from V-LEDS site would fit. i think they dont fit on mine bcuz the OEM lights for mine are round and the light from vleds are thin.
check out the pic below:
Wrap a think towel around some needle nose pliers and squeeze the bulb lightly and WIGGLE it.....don't pull cuz you'll only squeeze harder......wiggle side to side and up and down.....it will loosen and then pull it
well, i had to do it.
i took pics of all OEM interior lights of my '08 SRT8 import model so i can figure out which light to get from v-leds
pics from left to right:
1- Front Map - in place
2- Front Map - after i took the light off
3- Front Map - the light placed on the Map light cover to notice the size of the light
4- Front Map - another pic of the light placed on the Map light cover
5- Glove Box Light - its a 194 light
