First of all I KNOWWWWWWW, coolant temps vary, and its normal for it to climb..
Driving my 06 around town coolant stays around 190, nothing over.. Beat on it, still around 190. Sitting in traffic, or in a parking lot 190*. Always below 200* no matter what.
Well when you turn the AC on the coolant temps slowly start climing, sitting or moving. I shut the AC off when it hits 230*.. I dont let it get above that.. When its that high, and the AC is on, the fan doesnt seem to be on HIGH. Just low.
Johan adjusted my tune so my fan comes on early, but it still does the same thing.
Is there anyway to check the low / high setting of the cooling fan? It worked find before the blower install.. And I dont have air bubbles in the coolant.
Run a jumper wire for the high speed fan relay in the fuse panel under the hood. If it doesn't kick on, then you know you have an issue. I'm pretty sure it says which relay is which, but if not, I can send you pics later of the correct relay.
My Jeep always does this. Usually though it'll only get up to 215-220*. Been battling it for years. I finally gave up. It never overheats persay, just runs warmer. Keep in mind OP, the truck is designed to run in the 215-230* range from the factory. You're not really running "hot".
Well tonight, without the AC on. Sitting in traffic the coolant gauge climbed to 245* and "check gauges" came on. So I got out to look, fan isn't on period now. So I let it cool down and drove it home.
Now I need to tear into it tomorrow and find out what the deal is.
Well I jumped the relay. Low side relay turned the fan on and it didn't sound to good. Jumped the high side and of course it didn't sound healthy either.
Then I went to take a video to show you what it sounds like. Now it won't jump.
Spins by hand but won't jump or turn on while the motor is running.
Now what to do.... Wire in a aftermarket *better* cooling fan, or find a stock unit to put in there.
Also found out tonight my 2-3 shift is getting sloppy at wot.
Seems everyone is 1 week out or more on getting the fan to ship... Great.
Thinking about upgrading to a universal fan. But would rather just pop a new fan in.. Of course we cant find just the motor.. It has to be the whole shroud and all.
Thanks, but since this is my daily I had to order something today. So I picked one up from fleabay.. says it should be here before the 30th.. Hopefully my short commute doesnt overheat it..
Before the blower with AC on it never climbed that high. I know this is still normal operating temps. But it pegged before.
Cooling fan was not turning on high before. And it does now. So I'll keep watching it.
FYI I bought my fan/ shroud from eBay. 100$ shipped. I got it in 3 days and the shroud was cracked. Contacted seller and he refunded 40$. So I just swapped fan motor in my shroud.
Has more fan blades and feels like it pushes more cfm than my stock fan blade
Did you get this solved? I just started having this same issue. Only difference is im completely stock. While driving stays at normal 205* after sitting in parking lot it jumps to 220*, sure not overheating but why all of a sudden it just start getting hot? Could someone explain how to check my relays? Ive seene Harrions pics of his melted fuse panel, I dont seem to have that but aside from replacing both hs an ls relays along with throwing ina 180* tstat idk what to do.
hey, i have had this issue twice, its not the relays, the fan resistor and module goes bad...
get a mopar replacement (not dorman) it goes for $335 list, but you should be able to find it at a good stealership for $275.... once you swap the entire fan assembly u should be good to go.... with the 180 jet you should see temps at 181 idle and 188 if you are on a run... anything over 189 should raise a brow....good luck
So its in the whole fan assembly? Its a one fan deal with 2 speeds correct? Whole thing needs replaced? Thanks for the info I appreciate it. Even though I was hoping for a simpler cheaper fix haha
yeah the fan assembly with the module and resistor.......i have done this twice since i have owned the jeep....
my temps when fan is good never climb past 185.....100 plus runs stays cool 181 cruising around......
Related Threads
Cherokee SRT8 Forum
1.4M posts
46.9K members
Since 2006
