I have a SRT8 08 with 26K and i have to change the water pump (its leaking).
Im from PERU so i will need someone to help me with the code of the part and a web page to buy it.
Many thanks in advanced...
I doubt its the actual water pump leaking. Its most likely the neck on the water pump where the coolant hose slides over it. I noticed mine has started to leak with these cold temperatures recently. The gasket between the neck and where the thermostat sits is your problem.
Il already take it to the mechanic and he take it out... It was leaking from the middle of the pump, behind the pulley... he already fix it but it would not last so i have a couple of months to import a new one.
I f you hace the code part it would be great...
Leonardo
Theres a dealer around here but his prices are WAY HIGH....
example : JEEP SRT8 NEW 2009 (U$78,000)
Water Pump =U$580.00 and i have to wait 1 month until it arrive....
Thanks for the info, i will try to search it with the code...
Leonardo
FYI I found this Tech Tip when I ran the part number.
"The 5.7L/6.1L water pump is designed with an integral coolant reservoir tolubricate the shaft seal. If diagnosing a 5.7L/6.1L water pump for a seal issue, only replace the pump if coolant weepage is found coming from the seal reservoir (the small freeze plug at the 6 o'clock position on the pump body). Hose connections are often mis-diagnosed as a weeping pump and do not require replacment of the pump"
$580 Damn it is only $150 Cnd.
Related Threads
Cherokee SRT8 Forum
1.4M posts
46.9K members
Since 2006
