Help Info on Changing the Transmission - Cherokee SRT8 Forum
post #1 of 8 (permalink) Old 01-17-2013, 12:19 PM Thread Starter
jmkiesz's Avatar
Alright I am just looking for some info on changing out the transmission. Is it a large task that should be done by a shop or can it be done at home. I have a lift and most tools just never really got involved in any trans work. I repdlaced the valve body but all that is taking a cover off.
Thanks for any input you guys can offer.
07 BLK GCSRT on 22" FR with Nitto 420's
76 mm single Turbo
SHR Trans
Snow Performance Stage 3 Meth Injection,
3" Cutout w/MagnaFlow Cat-Back
jmkiesz is offline
post #2 of 8 (permalink) Old 01-17-2013, 12:39 PM
kmitch80's Avatar
just off the top of my head. gotta remove Tcase, cross member, bell housing bolts can be a pain in the A$$!! front driveshaft. and all lines. If you have a lift and the right tools. you can have it out in a few hours im sure. and i would guess install is reversal of removal. Just keep all your parts, nuts, bolts in order. take pics if ya need to. Should be pretty straight forward.
PWR 426
kmitch80 is offline
The Following User Says Thank You to kmitch80 For This Useful Post:
jmkiesz (01-17-2013)
post #3 of 8 (permalink) Old 01-17-2013, 12:39 PM
ekaz's Avatar
Not too difficult, I've swapped several in my garage without a lift. unbolt front/rear driveshafts from the tcase, remove tcase, disconnect electrical connector, disconnect shift linkage, unbolt tc bolts from flexplate, remove bell housing bolts. You will need to support the rear of the trans after taking the tcase out.
That's about it in a nutshell.
Make sure the 2 dowels come out with the transmission and don't get stuck in the block.
I'm BAAAAAAAACK....
2015 Billet Silver
past:
2012 300SRT
2009 Jeep SRT
2006 Charger SRT
ekaz is offline
The Following 2 Users Say Thank You to ekaz For This Useful Post:
jmkiesz (01-17-2013), R0ck39 (01-17-2013)
post #4 of 8 (permalink) Old 01-17-2013, 02:02 PM
cmn1's Avatar
Mark the top 4 bolts around the housing that you take out. They are a different thread than the bottom ones but they have the same size socket head.
cmn1 is offline
The Following 3 Users Say Thank You to cmn1 For This Useful Post:
jmkiesz (01-17-2013), Knuckles (01-17-2013), R0ck39 (01-17-2013)
post #5 of 8 (permalink) Old 01-17-2013, 02:13 PM Thread Starter
jmkiesz's Avatar
Thank you guys for the tips. I will take pics as I go so I have something to look back at if I get stuck. I am a little nervous but Im sure I will get through it.
jmkiesz is offline
post #6 of 8 (permalink) Old 01-17-2013, 03:05 PM
cmn1's Avatar
A trans jack is a great tool to have to put the new one in.
cmn1 is offline
post #7 of 8 (permalink) Old 03-10-2013, 08:03 PM Thread Starter
jmkiesz's Avatar
I marked the driveshafts but it was not there when I went back to install the front driveshaft. Will this cause me to have a small vibration problem. I took the truck out and all gears seem to shift alright and no crazy noise coming from the engine or trans. I take it out and slowly roll it into boost and I get a vibration under my feet. It kinda feels like it could be my front DS. The rear DS was put back the same way those marks stayed on. I changed flex plate new torque converter and new trans.
I have to take mid pipes back out to address a leak between the headers and mid pipe so getting to the front drive shaft will be easy but is there anyway check the front DS.
jmkiesz is offline
post #8 of 8 (permalink) Old 03-10-2013, 08:42 PM
Contributing Member
PITTZ's Avatar
First take off the front drive shaft and take it for a drive to see if the vibration is still there.
For me the vibration at my feet is my transmission output shaft because my front drive shaft is brand new.
Team Winter Build
PITTZ is offline
New Info Chart at WK2jeeps.com with Production Info Shake WK2 SRT8 General Discussion 1 03-18-2012 11:29 AM
Stock WA580 Transmission Upgrade Info Needed fstr n u WK1 Suspension / Driveline Discussion 7 02-23-2012 02:22 AM
NAG1 Transmission info and input torque capacity BuilderBill WK1 General Performance Discussion 88 10-21-2010 09:55 PM
Diablosport TRANSMISSION INFO!! BOOST ALMIGHTY WK1 Tuning/CMR/Dyno/DataLogging/Gauges 9 10-01-2007 04:58 PM
