Transmission failure? - Page 2 - Cherokee SRT8 Forum
post #11 of 21 (permalink) Old 01-16-2013, 07:42 PM
When did you last get your transmission serviced? There might be other issues but everything you describe will happen with improper fluid level, "low" fluid level will mess up shift pressures and can cause free wheeling as you describe and awful gear changes and slipping out of gear...
When we installed my SHR Viking, the shop did not use the proper required amount of fluid with a new convertor and it pretty much behaved exactly like your Jeep on the first test drive. Took it to the dealer, had it properly scanned and checked...they topped it up and no issues after.
Again, Fluid level might not have anything to do with your issues but I would rule it out first if you haven't already before investing big money.
I looked at all the transmission options when I surpassed what the stock unit could handle and found no better deal then the SHR...Skip is the man when it comes to great deals on these!
First Jeep is offline
The Following 3 Users Say Thank You to First Jeep For This Useful Post:
Cotton Picker (01-16-2013), DemonPerformance (01-16-2013), MattSRT (01-16-2013)
post #12 of 21 (permalink) Old 01-16-2013, 09:33 PM
On a side note, my stocker with blue tops handled 525-550 whrp with no issues.
It wasn't till I went to higher boost and surpassed these numbers that I needed better internals and a complete built unit.
And if you are looking at the "Arrington Stage 4", Give Bill a call before you pull the trigger on that for sure!
post #13 of 21 (permalink) Old 01-16-2013, 10:11 PM Thread Starter
MattSRT's Avatar
I actually got the transmission service probably back in around June or so.
To be honest the reason that I went to go and have the tranny flush was because of the issues I was having with limp mode on the 3-4 shift.
I guess it's worth looking into. Is it easy to check and top up or is this another trip to the dealer?
I'm pretty certain it's the transmission I mean it's going to have to be replaced anyway and seeing how there's a sale on, one way or another I should probably get an SHR.
I don't think I'm going to touch the stage 4 because it seems to be a pretty inferior transmission when you compare the two I found. The only tranny equal or better than the SHR seems to be Paramount, which I can't afford considering the difference with the group buy price. Lets just say its more than the usual $800+ more to begin with.
2008 WK1SRT8 - ARL Performance Machine 392 stroker, Thitek heads, Vortech V2 Ti (30 tooth), SHR Viking Gen II
diablotoona was here...
(PB below is on pump gas in about a 3000 DA)
MattSRT is offline
post #14 of 21 (permalink) Old 01-16-2013, 10:14 PM Thread Starter
MattSRT's Avatar
[QUOTE=First Jeep;984658]On a side note, my stocker with blue tops handled 525-550 whrp with no issues.
How long was the stock tranny in your jeep before you swapped it with your supercharger?
I mean I have over 25,000kms on my set up, I have no idea what my whp numbers would be but I'm sure not near 500 IMO.
MattSRT is offline
post #15 of 21 (permalink) Old 01-16-2013, 10:29 PM
The stocker was only in use for about 4 month's and about 12000kms supercharged at 525whrp... Blue tops were added to the stock transmission when I installed the Procharger. The transmission handled the power fine till i jumped to 600whrp.
It was the original transmission that had about 120,000kms on it and it was pretty much maxed out and getting tired. I started having a couple of issues at the same time...convertor and some 3-4th slip... Any upgrade or rebuild at my build stage would have meant a possible issue down the road so I decided to buy the SHR because more mods were in the future...
If you are supercharged on a completely stock transmission without a valebody upgrade or Blue Tops its only a matter of time...especially if you beat on it...
post #16 of 21 (permalink) Old 01-17-2013, 10:07 PM Thread Starter
MattSRT's Avatar
The stocker was only in use for about 4 month's and about 12000kms supercharged at 525whrp... Blue tops were added to the stock transmission when I installed the Procharger. The transmission handled the power fine till 600whrp.
Really? I was told that blue tops were harder on the tranny because of the harder grabbing. I guess I was told some false info.
Oh well, I'm going to go with the SHR anyway.
MattSRT is offline
post #17 of 21 (permalink) Old 01-17-2013, 10:26 PM
Not sure if you saw this...GREAT READ! Understanding your NAG1 Transmission
The Blue tops work just fine with a "stock valvebody", its a performance part Chryslar decided to change for the American market...You'll find bad reviews on these but thats usually from guys who don't give them a chance, and are completely brain washed by all the top dogs here running other "over priced options" that do the same thing...not saying anymore on that topic.
I would not jump at buying a new transmission until you know what is going on with yours...it maybe a simple issue. Not sure what type of shops you have around you so good luck with whatever you decide. If you go with the SHR you will be happy...mine is super tight and i'm happy with it...
post #18 of 21 (permalink) Old 01-18-2013, 04:23 PM
The SHR comes with Blue Tops installed.....
post #19 of 21 (permalink) Old 01-19-2013, 11:02 AM Thread Starter
MattSRT's Avatar
That's not the problem though. Mine had about 86,000kms when the supercharger was indtalled and has about 112,000kms now.
I got the transmission flushed just ghis summer at the dealer by a mechanic that had already rebuilt a nag1 from an srt8 Jeep. He would have addressed a low fluid issue earlier.
I say this because I was having issues before the flush with limp mode on the 3-4 shift and possibly some slippage.
Now I realize you were running in all likeliness a little more power than my Vortech, but I'm certain my transmission is failing now.
I have always been unable to tune it with THE BEST tuners here (Jerseyboy & Johan etc)
Because of it always going into limp mode before AND after the transmission flush.
Got an SHR on standby just waiting until I'm allowed to pay and hoping my stock tranny holds up a few more weeks.
Either way I'll need an SHR for long term life from my daily driven Jeep.
And yes I am aware the Viking comes with blue tops.
Thanks guys
MattSRT is offline
post #20 of 21 (permalink) Old 01-19-2013, 11:35 AM
You'll really like the new transmission...report back when you get it installed.
I was hoping it was a simple issue for you but it seems you have more going on with it.
The Following User Says Thank You to First Jeep For This Useful Post:
MattSRT (01-20-2013)
Merged: new member needs help transmission failure!!! ryanpeters32 WK1 Troubleshooting / Problems Discussion / Dealer Service 44 03-29-2012 04:29 PM
Audio Failure stang99x WK1 Troubleshooting / Problems Discussion / Dealer Service 2 08-26-2010 04:44 PM
Why the GTR is destined for FAILURE ! Razorecko Other Vehicle Makes & Models Discussion 27 01-23-2009 03:53 PM
HID failure sentipede WK1 SRT8 General Discussion 5 11-26-2007 06:58 AM
