NV146 Transfer Case Rebuild DIY - Page 2 - Cherokee SRT8 Forum
 2Likes
post #11 of 68 (permalink) Old 11-21-2012, 11:44 PM Thread Starter
If the notch is facing up or down when reinstalling the half of the case the dark gray arm will not sit flush thus causing the spring to stay depressed. If the spring is depressed the clutches stay together. I dont believe it directly relates to the tcase motor. If you look at the picture of the dark gray arm you will see two raised notches on the top and bottom(shiney silver due to pressing the plate). If the notch hits those it will not activate properly
2006 SRT8 Jeep: Black, AFE Stage 2 intake, 180 Jet Tstat, BT Catch can, Blue Tops, Vred 315 combo, 15% tint.
jabdelja is offline
The Following 2 Users Say Thank You to jabdelja For This Useful Post:
Jack_Toepfer (11-29-2012), Knuckles (11-22-2012)
post #12 of 68 (permalink) Old 11-29-2012, 12:34 PM
viking757's Avatar
So the question remains...what makes up the "high torque" transfer cases...
viking757 is online now
post #13 of 68 (permalink) Old 11-29-2012, 01:10 PM
I'm interested in this as well...seems like it can only be a part swap with better quality materials...I doubt it's modified like some of the valve body work.
First Jeep is offline
post #14 of 68 (permalink) Old 11-29-2012, 01:53 PM Thread Starter
From what i gathered from taking mine apart, all the parts are pretty beefy except for the clutches in the basket
jabdelja is offline
post #15 of 68 (permalink) Old 11-29-2012, 01:57 PM
Muellge's Avatar
key is getting another clutch in there. proper machining makes some room for it. I have had brand new spare in shop for a while now that's had a full colonoscopy.
Again, great write up. You got the issue with the locator notches on the arm in there too. Good sequential photos...
one more clutch.
Five Door League...
Muellge is offline
The Following User Says Thank You to Muellge For This Useful Post:
viking757 (11-29-2012)
post #16 of 68 (permalink) Old 11-29-2012, 07:43 PM
viking757's Avatar
I figured there wasn't much someone really could do and thanks again for the insight!
post #17 of 68 (permalink) Old 11-29-2012, 07:48 PM
Mongoose9400's Avatar
I always heard the clutch plates were carbon fiber and hence the reason for the NV146 fluid. Is that true?
Zac
SOLD 2007 Silver Jeep SRT8
Mongoose9400 is offline
post #18 of 68 (permalink) Old 11-29-2012, 07:52 PM
viking757's Avatar
Now you have me thinking if there are any clutches and plates made with different material that may fit our TC...
Found some good info regarding different materials
http://www.uucmotorwerks.com/clutch/
post #19 of 68 (permalink) Old 11-29-2012, 07:57 PM
Cool link and info
post #20 of 68 (permalink) Old 01-07-2013, 02:40 PM
Muellge's Avatar
anyone ever figure out the weight and spec on our T/C fluid. I know is smells like burnt garlic mudbutt, but anyone know the numbers on it?
Muellge is offline
Tim H Calgary (01-09-2013)
Moved: NV146 Transfer Case Fluid WIPLASH WK1 Suspension / Driveline Discussion 5 10-08-2012 09:03 PM
