have ?s not sure what I need to replace - Cherokee SRT8 Forum
post #1 of 3 (permalink) Old 11-13-2012, 06:32 PM Thread Starter
WhiteFeatherMen's Avatar
Ok guys see if you can help me on this one. I have been experiencing a grind and a pop in the front passenger side when the vehicle rolls from 0-25 under light excel. as if a gear in the front diff is slipping and then finally engages. I sometimes feel as if the is some play in the front diff as well in stop and go traffic and do notice a slight knock. I have it down to 3 possible things that could be causing this problem. 1. Front Carrier. 2. Drive pinion. 3. Transfer Case. I do experience a slight shutter around 65mph as well. I would like to get opinions on what it is.
I just recently replace the rear carrier due to the pin that retains the spider gears shearing off and destroying the drive pinion. It was having similar symptoms as I am having in the front diff. Just trying to nail this thing down with out having to replace parts that dont need to be replaced.
2007 GC, Vivid Black, Toyo Proxies STII 275/315, Up coming mods... 4" Bwoodys CAI, Catch Can, and still deciding on what tuner Im getting form DiabloSport, Trinity or inTune?
"There is nothing so pleasing as to be shot at by one’s enemy without result."
- Winston Churchill
WhiteFeatherMen is offline
post #2 of 3 (permalink) Old 11-13-2012, 11:14 PM
jkalbin's Avatar
It might sound silly, but get under the jeep and see if the front diff. bushings are shot. It will cause a clunk when the driveline gets loaded/unloaded as the diff housing will rotate under load. Just get under there and lift on the pinion and see if the diff moves. Bushings would be the cheapest fix, best to check that first
2010 SRT8: BT Catch can, Carbon Fiber Shorty Ant., LMI Carbon Fiber CAI, Custom painted headlights/side moldings, Passport 9500ix Corvette mounted and direct wired, LED interior, Weathertech floor liners, Trinity w/vent mount, Bwoody sway links, Motivos, JOHAN TUNE! (rev 007
jkalbin is offline
post #3 of 3 (permalink) Old 11-14-2012, 12:24 PM Thread Starter
alright thanks man ill check that out
What Should I replace to use more lb of boost? baccocafe WK1 Engine Performance/Superchargers/Turbos/Nitrous 23 12-15-2011 06:26 AM
Anyone ever replace their AFE Filter? Rez90 WK1 Intake/ Exhaust Discussion 2 04-03-2011 01:15 PM
Replace 2007 Nav?? Halla19 WK1 Audio/Video/Nav/UConnect/Electronics 2 01-21-2011 10:36 PM
Anyone have to replace their Alt. yet? Harrison@Stage6 WK1 Troubleshooting / Problems Discussion / Dealer Service 21 07-30-2010 10:58 AM
Anyone ever have to replace fan relay? DLA WK1 Troubleshooting / Problems Discussion / Dealer Service 20 12-23-2009 11:37 AM
