Grease fittings on Bwoody end links? - Cherokee SRT8 Forum
post #1 of 18 (permalink) Old 08-16-2012, 08:51 PM Thread Starter
CarCrazyRDM's Avatar
For those that have installed these on your Jeep, did you order them with the grease fittings? Is it worth the extra $25 or can I just save that money and get the "regular" fittings and just grease them up good when I install them?
Thanks for any input,
Ryan
2008 Silver Jeep SRT8 - 13.02 @ 103 mph w/ 1.81 60ft (stock)
______________________12.74 @ 106.8 w/ 1.76 60ft (CAI, Oil Sep. & Toona Tune)
2006 Silver Magnum SRT8 - H/C/I + Vortech
CarCrazyRDM is offline
post #2 of 18 (permalink) Old 08-16-2012, 09:01 PM
jon1990's Avatar
Just buy the grease yourself
Sent from my iPhone using Autoguide
07 red rock, cam, jew tune, intake, 275/315, shr trans, direct port nitrous express kit, ported manifold and supporting goodies,
jon1990 is offline
post #3 of 18 (permalink) Old 08-16-2012, 09:11 PM Thread Starter
I'm not worried about the grease, I have that, just wondering if I get the bushings without the grease fittings if I am going to have to take the damn things off every six months and grease them to keep from having squeaks. Or are guys that have bought the ones without grease fittings finding they can go years without greasing them as long as you lather them up nicely upon install.
Thanks.
post #4 of 18 (permalink) Old 08-16-2012, 09:15 PM
cmn1's Avatar
I have never greased mine and they have been on for at least 5yrs.
cmn1 is offline
The Following User Says Thank You to cmn1 For This Useful Post:
CarCrazyRDM (08-17-2012)
post #5 of 18 (permalink) Old 08-16-2012, 09:17 PM
jon1990's Avatar
I've had mine for 7 months now and mine are good
jon1990 is offline
The Following User Says Thank You to jon1990 For This Useful Post:
post #6 of 18 (permalink) Old 08-16-2012, 09:31 PM Thread Starter
Sounds like maybe I will just save the $25 and get them without the fittings. Thanks guys.
PS A follow up question that I'll do a search for in a minute but can you really see these links from outside the truck? Meaning, does it really matter what color I get them in? Quite honestly I think I'd rather they just be black even if you can see them just so they blend in.
post #7 of 18 (permalink) Old 08-16-2012, 09:41 PM
centxsrt8's Avatar
If you lay down you can see them, but you have to know where you are looking for. Just get them in wrinkle black and have them blend in.
Sam
2009 Brilliant Black
centxsrt8 is offline
The Following 2 Users Say Thank You to centxsrt8 For This Useful Post:
CarCrazyRDM (08-17-2012), cmn1  (08-17-2012)
post #8 of 18 (permalink) Old 08-17-2012, 01:45 AM
WIPLASH's Avatar
I've had mine with no fittings for about two years now and no problem with them. The grease fitting is unnecessary IMO.
I spray some lithium grease every now and then to prevent squeeking but it's probably not needed either if everything was torqued down properly.
I'm gettting frustrated
with modding
WIPLASH is offline
The Following User Says Thank You to WIPLASH For This Useful Post:
post #9 of 18 (permalink) Old 08-17-2012, 07:21 AM Thread Starter
Thanks guys.
post #10 of 18 (permalink) Old 08-27-2012, 10:58 PM
I spent the extra $25 for peace of mind. Considering what some routine maintenance costs are, such as transfer case fluid changes, the extra $25 for a permanent install is a drop in the bucket.
2008 GC SRT8 - Techco Supercharger @ 5.3lbs, Paramount Stage II VB, Paramount Tranny Cooler, Walbro 400lph pump, HHP Tuned, BT Catch Can, QTP Cutouts, Borla S, QA1s, End Links, Volt 4300k HID fogs, Stant 18# cap, 1 pc Upper Hose, 180 thermo, WeatherTechs & Liquiddomes, Custom Stereo, Cryoed R1s/Stoptechs/ATE Super Blue, painted calipers, 22" Bonspeeds and CF Medic V1 hood.
Injuredoften is offline
Bwoody links g00zfraba6.1 WK1 Suspension / Driveline Discussion 1 10-12-2011 08:02 PM
bwoody end links emarati WK1 Suspension / Driveline Discussion 2 06-07-2010 09:44 AM
How do you grease your links? robpp WK1 Suspension / Driveline Discussion 2 10-04-2009 09:04 PM
Issues with BWoody End links and Addco Sway Bars and BWoody springs are on... Harrison@Stage6 WK1 Suspension / Driveline Discussion 19 11-24-2008 10:56 PM
