Addco FRONT swaybars. Need opinion on effectiveness versus stock front bars. - Cherokee SRT8 Forum
post #1 of 21 (permalink) Old 08-28-2011, 03:19 PM Thread Starter
silverbullet's Avatar
Guys,
I have long since replaced my factory rear swaybars with the Addco replacements and have been VERY happy with their immediate effect on my handling.
I was wondering from those that replaced their factory front swaybars what if any were the improvements? The addco bars are marginally larger than the stock ones so I did not do these 2 years ago.
But having a road course event coming up, I am now thinking of doing these.
Thoughts?
SLEEPING BEAUTY - STOCK looking, bone crushing fun
Vortech V3 (10 psi)/PWR 393/PWR mild cam/AR headers/ATI 17% overdrive pulley/Corsa Exhaust/SHR trans/PI 2800/QA1/Tuned by Johan
silverbullet is offline
post #2 of 21 (permalink) Old 11-17-2012, 12:02 PM
nyjoed's Avatar
Where did u purchase the bar from? Easy install?
72mm FOGLIGHT TWIN TURBO
nyjoed is offline
post #3 of 21 (permalink) Old 11-17-2012, 12:13 PM
Jeep Trick's Avatar
I also have always been on the fence with this but have not done it
I have heard of fitment issues with the front that I don't know whether or not have been corrected or not.
Most will say its not worth it but I dont know if thats really from experience or not or just an opinion
I will say my jeep as is handles very well
Bwoody links, JBA UCA, Eibachs, rear addco sway and vreds w/modified oem bump stops
Jeep Trick is offline
post #4 of 21 (permalink) Old 11-17-2012, 01:18 PM
Premium Whore (Lifetime)
StangSlayerMA's Avatar
I installed them with my Bwoody springs 3 years ago. My Jeep handles like its on rails. The front sqeeks and creeks, so I'm constantly spraying Fluid Film in the bushings.
StangSlayerMA is offline
post #5 of 21 (permalink) Old 11-18-2012, 05:03 PM
cmn1's Avatar
I think for the size difference they aren't worth it and haven't done it. For the most part it is just an opinion because no manufacturer of parts ever tests their parts. They make them and let us be the guinea pigs. That's what sucks about being a limited build.
cmn1 is offline
post #6 of 21 (permalink) Old 10-29-2013, 08:04 PM
nubtard's Avatar
reviving a old thread
installed both front and rear, previously had the road magnet springs. Great improvement.
jacking up the rear from in front of the 4 link, on one side now lifts the front wheel a lot sooner then before , cant wait to throw it into some good corners.
The first F1C jeep, Now on facebook, Go check it out -->>>>
Minnesota Users look here ---->.
SRT stands for = Sexy Red Truck
nubtard is offline
post #7 of 21 (permalink) Old 10-29-2013, 08:09 PM
nyjoed's Avatar
Have had mine on for a few months now and I feel a positive improvement but not super significant. Deff a bit more like on rails and less roll. I give them about a B to a B+
Sent from AutoGuide.com App
nyjoed is offline
post #8 of 21 (permalink) Old 10-29-2013, 08:25 PM
Stang352's Avatar
I have a Front and Rear set. I swapped my Front Addco sway bar back to the stock sway bar. I could not stand the noise and the improvement with Addco was minimal for me.
Stang352 is offline
The Following User Says Thank You to Stang352 For This Useful Post:
tugboatchad (10-29-2013)
post #9 of 21 (permalink) Old 10-29-2013, 08:57 PM
Premium Reformed Member
tugboatchad's Avatar
I'm about to reinstall my front stock sway. To noisy.
tugboatchad is offline
post #10 of 21 (permalink) Old 10-29-2013, 10:34 PM
nubtard's Avatar
grease? diff bushings?
nubtard is offline
Swaybars Addco vs stock srt???? AGRAV8ED WK1 Suspension / Driveline Discussion 18 05-11-2010 10:38 PM
Front Addco sway bar vs. front SRT8 sway bar... specs? JDub WK1 Suspension / Driveline Discussion 3 03-02-2010 03:54 PM
Addco sway bars - Greasable bushings front and rear robpp WK1 Interior/Exterior Visual Modifications 6 07-17-2009 08:44 PM
