Transmission Cooler Install (Paramount Performance Products)How To - Cherokee SRT8 Forum
post #1 of 19 (permalink) Old 12-17-2015, 06:42 PM Thread Starter
Ok, So I decided to install a Converter, Flywheel (flex plate) and cooler by myself at home using basic tools.
I contacted Builder Bill and He took my information so he could design the three mentioned items (no affiliation with the company or discounts, so I am just a normal customer paying full price). the transmission R&R, converter and flywheel took me about ten hours by myself, with a small case of turrets on my part so there are no Damn pictures.
I did manage to calm down (thank God for sweet delicious beer) and decided to document the cooler install. so here it goes.
I decided to delete the factory cooler and install the cooler at the rear of the jeep. after a lot of head scratching and development of a list for the items I needed, I placed an order to obtain my parts (AN fittings and hoses).
In progress,
2006 Black GCSRT8,
baja272 is offline
post #2 of 19 (permalink) Old 12-17-2015, 06:56 PM Thread Starter
It will take me a while to figure out how to post these photos. please be patient.
All you really need is Paramount Performance Products Transmission cooler. It has all the hoses and fittings needed to do this except one piece of 2x4" angle and a couple of bolts.
I wanted different lines so here goes. I used Russell Fittings, there are others that are less expensive.
  • Transmission Cooler kit, code # 13960
  • 2, -8 flare to 1/2 npt, #660493
  • 2, -8 45* hose ends, #610105
  • 1, -8 90* hose end, #610175
  • 1, -8 120* hose end, #613415
  • 30', -8 hose, (I used pro race hose)
  • 1, 3' long 2x4" angle, I used aluminum
  • 1, 5/16" x 3.5" bolt, nut, and 2 washers
  • 4, 5/16 x 1", bolt, nut s and washers
  • 3 quarts of ATF
baja272 is offline
post #3 of 19 (permalink) Old 12-17-2015, 09:19 PM Thread Starter
The cooler is mounted outboard of the crash box as far to the rear and as high as possible as possible. I made brackets out of 2 by 4 inch aluminum.
baja272 is offline
post #4 of 19 (permalink) Old 12-17-2015, 09:25 PM Thread Starter
Outboard passenger side of rear crash box NOTE, the bracket size is 2"x4" not 1x3"
baja272 is offline
post #5 of 19 (permalink) Old 12-17-2015, 09:33 PM Thread Starter
Now to the transmission. -8 male (flare) by 1/2 inch npt fitting used for the ports that transfer the fluid to the cooler lines
baja272 is offline
post #6 of 19 (permalink) Old 12-17-2015, 09:41 PM Thread Starter
Install the 1/2 inch side of the fitting with a liquid thread sealant (used Loctite 567) into the transmission here (near the bell housing where the factory cooling line was).
baja272 is offline
post #7 of 19 (permalink) Old 12-17-2015, 09:50 PM Thread Starter
On the passenger side I used this hose end
baja272 is offline
post #8 of 19 (permalink) Old 12-17-2015, 09:53 PM Thread Starter
Similar setup as the passenger side except I used a 90 degree -8 hose end
baja272 is offline
post #9 of 19 (permalink) Old 12-17-2015, 10:09 PM Thread Starter
Run the two -8 hoses over the top of the transmission and to the rear of the truck inside of the gas tank brackets (there is plenty of space between the gas tank and the gas tank mounting brackets) closest to the rear drive shaft tunnel.
baja272 is offline
post #10 of 19 (permalink) Old 12-17-2015, 10:11 PM Thread Starter
Saved for future post/Images
baja272 is offline
Paramount Performance Trans Cooler arrived today 1BAMFR WK1 Suspension / Driveline Discussion 14 12-22-2012 07:50 AM
Paramount Performance Products New Training Video! Robert0685 Off-Topic Discussion 13 10-22-2009 09:28 PM
