OEM IAT sensor removal? - Cherokee SRT8 Forum
post #1 of 12 (permalink) Old 02-17-2013, 01:27 PM Thread Starter
Tyson33's Avatar
So trying to install my 4" BWoody CAI and unsure how to remove the OEM IAT sensor from stock tubing. My BWoody didn't come with a new sensor...any help would be great!
'08 Black Jeep SRT8
D1 ProCharger & RRV / SHR Trans / Corsa Exhaust / SW Headers / PWR Custom Cam / BT Catch Can / 180 T-Stat / Trinity & Toona Tuned / FR Chrome 22's on 265/315 Vreds / Eibach's / R1 Drilled & Slotted Rotors / StopTech Pads / Murdered Quad Retrofit Projectors & Red Demon Eyes / Shorty Antenna / TS Rear Fog Harness /
Tyson33 is offline
post #2 of 12 (permalink) Old 02-17-2013, 01:32 PM
bennett15's Avatar
just did this last week let me tell you it was a real pain in the ass took my longer to get the damn thing out then it did to install the whole intake. i had a buddy hold the intake tube and i pryed and pulled in it with a flat head screwdriver be very careful doing this not to damage the sensor. it takes a lot of force
Trinity, Jet 180 T-STAT, Mygig Swap, Ebiach Pro Kit, Borla S, DC Customs Lights, R1 Concepts Drilled/Slotted Rotors, StopTech Pads, BT Catch Can, Continental DWS 275/315s, Passport Max, Vortech V3 w/ FMIC & Wastegate, Stage 6 2-Step, PML Diff Cover, Custom Projector Fogs. Adjustable Panhard Bar, Snow Water/Meth, SHR Viking, 6500 PTCM
bennett15 is offline
post #3 of 12 (permalink) Old 02-17-2013, 01:33 PM Thread Starter
Tyson33's Avatar
Alright thanks man! I guess I'll go man up...
Tyson33 is offline
post #4 of 12 (permalink) Old 02-17-2013, 04:01 PM Thread Starter
Tyson33's Avatar
How do u get the filter down in there without scratched up all the sides of it!?
Tyson33 is offline
post #5 of 12 (permalink) Old 02-17-2013, 05:16 PM
bennett15's Avatar
i moved my coolant tank out of the way and i pushed the inner fender well inwards as it is able to flex faily easily and i had the filter mounted and tightened down on the intake tube then pushed it into the bumper it was pretty tight but i did not scratch mine and found it easier then laying under neath and mounting filter afterwards.
post #6 of 12 (permalink) Old 02-17-2013, 05:25 PM
roadboy's Avatar
+1^^ what he said
11.79@113
Electric exhaust cuts outs
roadboy is offline
post #7 of 12 (permalink) Old 02-17-2013, 06:36 PM
LASRT's Avatar
Heat the rubber up and it will come right out.
Adam salsbury - 2010 srt8, pwr camshaft installed at stage 6 running 12.6's
LASRT is offline
post #8 of 12 (permalink) Old 02-17-2013, 07:57 PM Thread Starter
Tyson33's Avatar
Finally got it! Thanks fellas! Click image for larger version
Name:	ImageUploadedByAG Free1361156240.322339.jpg
Tyson33 is offline
post #9 of 12 (permalink) Old 02-19-2013, 12:11 PM
Premium Reformed Member
tugboatchad's Avatar
Turn your tires to the right, jack the jeep up a bit on the passenger side (use a jack stand) and go from underneath with the filter. Wipe with your finger a very little amount of WD-40 around the rim of the opening on the filter and it'll slide right on.
Sent from AutoGuide.com App
tugboatchad is offline
The Following User Says Thank You to tugboatchad For This Useful Post:
Tyson33 (02-19-2013)
post #10 of 12 (permalink) Old 04-22-2013, 11:05 AM
tony0713's Avatar
do you need the extension to run the CAI?
tony0713 is offline
removal help pmpn8ez WK1 Interior/Exterior Visual Modifications 4 02-13-2010 09:03 PM
TCM removal vicioussrt WK1 General Performance Discussion 9 07-06-2009 10:48 PM
backup sensor bar removal ? CustomCaddys WK1 Interior/Exterior Visual Modifications 1 06-02-2008 08:59 AM
PCM Removal MARK16 WK1 Tuning/CMR/Dyno/DataLogging/Gauges 8 06-20-2007 09:07 AM
PCM removal Squilly D WK1 Tuning/CMR/Dyno/DataLogging/Gauges 8 06-04-2007 08:25 PM
