Oill Fill Breather Filter? Yes or No? - Cherokee SRT8 Forum
post #1 of 11 (permalink) Old 12-31-2012, 04:20 PM Thread Starter
PhillySRT8's Avatar
Hey guys, hope everyone has been enjoying the holiday season!
I recently installed my Bwoody 4" and BT catch can. I've run into two seemingly minor issues. First, the stock tube running from the air box to the oil fill neck obviously can no longer be used, so I am running a pvc flexible tube from the oil fill around to the little nipple(?) on the Bwoody. Basically I think it looks sloppy and also pushes against the catch can so I have ordered a small breather filter like I've seen on a few rides around the forums. Is this generally the way to go or should I keep a tube going directly from the oil fill to the nipple on the Bwoody? Any drawbacks or tips? I've heard of a few people having problems with an oily mist coming from the filter, and I'm hoping to avoid that altogether with a good tight install. Went with this filter to install on the oil fill: http://www.knfilters.com/search/prod...x?Prod=62-1320
Secondly, while installing the catch can (which I love, by the way), the lower hose seems to be pretty pinched between the back of the alternator. I'm going to go back and fiddle a little more to see if I can't get it to wedge on tighter and eliminate some of the pinch, but could this pose a problem? My assumption was that it couldn't be that big a problem unless it was running under some high pressures which catch cans are not. I'm using braided lines in case that factors in at all.
Thanks in advance! Happy New Year!!
Black 2008 Jeep Grand Cherokee SRT8- 15% Tint, Shorty Antenna, HHP/BES Stage 2 Cam, Dyno Tune, Borla-S, Eibach Springs, Vred Sessanta 275/315 flavor, Bwoody 4" Intake, BT Catch Can
PhillySRT8 is offline
post #2 of 11 (permalink) Old 12-31-2012, 04:37 PM
nyjoed's Avatar
Breather filter is fine I run one and never had 1 issue in 3 years. The catch can I also run braided lines with no issues. Try to get that bottom line on all the way and jus pinch it to kinda change and keep it somewhat round
72mm FOGLIGHT TWIN TURBO
nyjoed is offline
post #3 of 11 (permalink) Old 01-02-2013, 09:22 PM Thread Starter
PhillySRT8's Avatar
Well I just received the filter tonight and tried to put it on the fill. 3/8" is apparently too small. Shucks. Looks like I'm running the bootleg tube a little while longer now... Do you know what size and style your filter is? Any help is much appreciated!!
post #4 of 11 (permalink) Old 01-02-2013, 09:25 PM
nyjoed's Avatar
U need the one that's about .59" it slides right over the little nub that comes out from right under the oil cap
nyjoed is offline
post #5 of 11 (permalink) Old 01-02-2013, 09:26 PM
WIPLASH's Avatar
Force it in there, it's tight the first time around.
Sent from my balls.
I'm gettting frustrated
with modding
WIPLASH is offline
post #6 of 11 (permalink) Old 01-03-2013, 02:16 AM
urntfstenuf's Avatar
Sent from my balls.
aint that the truth! we are talking about the same thing, right!
07 SRT8 with Johan tune, Flowmaster exhaust, & cai. just a few mods.
urntfstenuf is offline
post #7 of 11 (permalink) Old 01-03-2013, 05:40 AM
WIPLASH's Avatar
I hope so...
Sent from my balls.
WIPLASH is offline
post #8 of 11 (permalink) Old 01-03-2013, 07:49 AM
stanfna's Avatar
The little bit of pinch is no problem. It is a tight fit though!!!
2010 fully loaded
Performance: ProCharger D-1SC, DMH cutouts, BT Catch Can, 180 tstat
Other: Toyo Proxes STII 315/275, slotted/dimpled R1 Rotors & Stoptech pads, Full interior LEDs, HID reverse lights, rear fog light harness, CHR550 w/ front facing camera, liquidomes, 5% tint, Shorty antenna, debadged, SRT8 badge on 1/4 panels, SRT in the lower grill, tinted tails
stanfna is offline
post #9 of 11 (permalink) Old 01-03-2013, 07:52 AM
stanfna's Avatar
as for the filter....i think most use this one...
http://www.autozone.com/autozone/acc...er=266500_0_0_
$10 at AutoZone
stanfna is offline
post #10 of 11 (permalink) Old 01-04-2013, 09:53 AM Thread Starter
PhillySRT8's Avatar
$10 at AutoZone
Thanks! I'll get on that today, appreciate the help
Crank-case breather filter Wintermute WK1 General Performance Discussion 14 07-12-2013 10:24 AM
Need a little help with catch can install, also ? about breather filter Shawn1112 WK1 Troubleshooting / Problems Discussion / Dealer Service 6 12-28-2012 06:34 PM
Crank case breather filter Ezituper WK1 SRT8 General Discussion 11 04-10-2012 05:32 PM
crankcase breather filter whistles now wtf!? A.V.GCSRT8 WK1 Troubleshooting / Problems Discussion / Dealer Service 4 04-21-2011 10:26 AM
Oil filter breather midwestsrt8 WK1 SRT8 General Discussion 8 04-19-2010 08:14 PM
