Question about kooks/check engine light!!! - Cherokee SRT8 Forum
post #1 of 14 (permalink) Old 04-07-2007, 02:22 PM Thread Starter
Hi guys my name is john and I live in williamsburg ,Va.I just had installed catless kooks headers and I have a dashhawk.I know I am going to throw some codes every 100 miles or so but I keep throwing Two different codes
every 30-40 miles.
The first one is for each of the cats.(witch is normal)
The second one is slow responce with 02 sensor.
Is this normal
UDLOSE is offline
post #2 of 14 (permalink) Old 04-07-2007, 08:40 PM
FastSRT8GC's Avatar
Re: Question about kooks/check engine light!!!
Not sure.. there are lots here with this experience good luck. Mine go on this week.
FastSRT8GC is offline
post #3 of 14 (permalink) Old 04-10-2007, 09:43 PM Thread Starter
Red face Re: Question about kooks/check engine light!!!
The codes i keep throwingare:
po420-Cats
po153-heated oxygen sensorslow responce
po133- circuit slow responce
po128-unknown
I am just worried I will blow my motor from running the wrong way.
Please any insight???
UDLOSE is offline
post #4 of 14 (permalink) Old 04-10-2007, 09:46 PM
po420-Cats
po128-unknown
The header/secondary 02 related MIL/CELs do absolutely nothing to performance, tuning, or your motor. They are simply an inconvenience.
GotStroke? is offline
post #5 of 14 (permalink) Old 04-10-2007, 09:53 PM Thread Starter
Thanks man I really appreciate your help.
Do you know what the po128 means?
UDLOSE is offline
post #6 of 14 (permalink) Old 04-11-2007, 03:07 PM
Grip Grip's Avatar
A quick google search said "code PO128; coolant temp below thermostat regulating temp"
Anthony
Grip Grip is offline
post #7 of 14 (permalink) Old 04-11-2007, 03:13 PM
tommy25000's Avatar
dont worry guys.... i throw those codes too. just clear them. no harm done just a pain in the a$$
2007 GC SRT 8 (sold)
2004 SRT 4 (sold)
2005 E55 ///AMG
2003 SVT COBRA 660/654wheel
2006 Lincoln mark LT
tommy25000 is offline
post #8 of 14 (permalink) Old 04-11-2007, 03:44 PM
po420-Cats
po128-unknown
Mine throws PO420 & PO430 "Inefficient catalytics"...thats it.
PO153 may indicate the heated sensor is not coming up fast enough. We have heated or self heating 02 sensors that bring it up to temp for quicker warm ups. You may have a bad 02........ or did you happen to install the 02 sensor bung spacer?? If so that could be the problem.
generalconfusion is offline
post #9 of 14 (permalink) Old 04-11-2007, 05:27 PM Thread Starter
Will this hurt anything or just throw a light??
UDLOSE is offline
post #10 of 14 (permalink) Old 04-11-2007, 05:57 PM
From what I have seen it may cause some slight fuel/air adjustment......but remember the ECU will never let it run much outside of federal emission standards.
If anything when we install headers....cams...heads.....the ecu will always take the engine management back to baseline......so no you wont melt a piston or burn a valve.
If nothing else see if you have a spacer in the 02 sensor bung. Check the 02 sensor.....you might have a bad heater on one of them.
Check Engine Light Aaron WK1 Troubleshooting / Problems Discussion / Dealer Service 14 05-19-2011 07:57 PM
Check Engine light just came on twentworth22@hotmail.com WK1 Troubleshooting / Problems Discussion / Dealer Service 3 11-21-2006 04:16 PM
Rear Fog Light Question TXBLU WK1 Interior/Exterior Visual Modifications 11 11-05-2006 08:03 AM
WTF----SES light, no AC and over heating... BLO BY U - TA WK1 Troubleshooting / Problems Discussion / Dealer Service 1 08-21-2006 01:35 PM
Break-in Procedures AaronC WK1 SRT8 General Discussion 2 08-05-2006 07:03 AM
