The Volant intake arrived, can't wait to install later this weekend. I will also try to "clean up" the lower brake snorkle - dryer flex line - intake connections. I will try and do back to back tests next weekend at Rockingham Dragway. I am sure that tis will not hurt performance like so many others, may even help over my modified factory air box.
Any hints on getting the sensor out of the existing rubber tube?
Bill
If the Volant didn't come with it's own grommet, and you need to re-use the one you have now, use a hair dryer or heat gun to warm the grommet up a bit. Be really careful if you use a heat gun, to not melt it. Soapy water also works well.
Bill
Bill
Lower snorkel assembly not included. I am trying to come up with something that looks as classy as the rest of the assembly. It is certainly the best I have seen to date.
Bill
PS. Maple flooring in photos installed diagonally by me!
What is also good for those connections to go in easy is di electric grease I had every CAI out so far and the sensor slides out very easy Iam waiting for my volant now
Go to home depot buy 3in PVC with a 90 elbow one 3in coupler some black paint. If you cut the brake scoop correct you can wedge the pvc into it and you only will need the one coupler. A few screws into the brake scoop and through the pvc to prevent it from moving. To wedge the pvc in the scoop you will have to cut the 3in PVC tube and have a small 3-4 inch section on the end of the 90 elbow.
That is the one. I liked the closed box design that had an open bottom tube for my brake ram air tube. I received mine from Southern Hotrod. Great vendor!!
Bill
I'm hoping to have it shipped directly here. I hate paying for shipping to my US address and then again to have shipped here. I am thinking CAI, possibly ported heads, intake, and maybe some nice wheels and tires.
