DUB Air Cold Air Intake installed... - Cherokee SRT8 Forum
post #1 of 2 (permalink) Old 11-14-2006, 08:49 PM Thread Starter
Talking DUB Air Cold Air Intake installed...
Took if for a spin after installation. Instructions said it will take about 100 miles for the engine controller chip to adjust for the increased air flow. Here is what I noticed right away.
1) Normal acceleration, no additional noise or roar, a bit more responsive.
2) Moderate acceleration, a tad bit more roar, noticing the responsive more.
3) Harder acceleration, the thing screams...deep roar, much more responsive, pulls harder in acceleration and yes, you can tell the difference in acceleration. Definitely a lot more punch! I am very please with the performance and operation of the system.
Some tips.
1)Rather than waisting time wrestling to get the orginal cold air flow mass/temp sensor out, I went and got another one for the Dub Air intake.
2) Soapy water helps on the install when joining the metal to hoses or getting the clamps into position and working with the sensor.
3) On the cold air box, I bent the four tabs upward a bit more towards the top of the box to give a snugger lock in at the back since the front locking snap should secure it properly when locking it down...more of a spring locking.
4) By proper aligning the system, you can use the hosing connecting the air filter to the main tubing to seal off the hole in the air box more snuggly around the black rubber gasket.
5) I routed the the smaller hose on top of the red elbow joint to avoid any contact with bolts. Dub routes in under the elbow. Too close to moving belt, hot block and potential bolt abraision. I used a large tie strap to secure it.
SRT Canuck is offline
post #2 of 2 (permalink) Old 11-14-2006, 09:48 PM
limeylee's Avatar
Re: DUB Air Cold Air Intake installed...
Had very similar results with the Mopar...Love it so far.
Pretty easy install, had a problem with the O2 sensor and the bolt holding on the stock air box, but all in all not too bad.
Money coming Bob.
limeylee is offline
GS MOTORSPORTS srt8 JEEP cold air intake GSMSales WK1 Intake/ Exhaust Discussion 38 05-31-2007 04:46 PM
MOPAR cold air intake 72RIV WK1 Intake/ Exhaust Discussion 71 11-12-2006 12:04 PM
**GS MOTORSPORTS** Labor Day group buy on our Cold Air Intake GSMSales WK1 Intake/ Exhaust Discussion 4 08-31-2006 07:36 PM
K&N Cold Air Intake Antares WK1 SRT8 General Discussion 8 08-01-2006 09:59 PM
Grand Cherokee SRT8 Dub Air Intake SRT8GC WK1 Intake/ Exhaust Discussion 0 06-09-2006 01:38 PM
