Mopar/Corsa Dyno Results - Cherokee SRT8 Forum
post #1 of 15 (permalink) Old 09-08-2006, 04:16 PM Thread Starter
Black_SRT8's Avatar
A soldier from the blue site just independently dynoed the Mopar/Corsa system.
Here are the results...
Stock = 353 hp (5900 rpm) & 336 tq (4958 rpm)
Mopar/Corsa = 373 (6333 rpm) hp & 342 tq (4955 rpm)
Black_SRT8 is offline
post #2 of 15 (permalink) Old 09-08-2006, 04:29 PM
Re: Mopar/Corsa Dyno Results
Those are some good numbers for just a catback however i think the corsa is to quiet for my taste.
BLKltng is offline
post #3 of 15 (permalink) Old 09-08-2006, 08:04 PM
Well that just sealed it for me, thanks.
viol8r is offline
post #4 of 15 (permalink) Old 09-11-2006, 11:10 AM
wow, nice numbers
srt8suv is offline
post #5 of 15 (permalink) Old 09-11-2006, 02:24 PM
353 hp, what type of dyno did you use?
FLSRT8 is offline
post #6 of 15 (permalink) Old 09-11-2006, 02:53 PM
Here is the dyno sheet sgt stanko (blue site) did ............stock vs Mopar/Corsa
http://i77.photobucket.com/albums/j6...ilarcorsa1.jpg
generalconfusion is offline
post #7 of 15 (permalink) Old 09-11-2006, 02:54 PM Thread Starter
Black_SRT8's Avatar
Like I said, I did not perform the test. A "soldier" from the blue site used the XS dyno. I believe it measures HP at the wheels.
post #8 of 15 (permalink) Old 09-11-2006, 03:13 PM
Yes......It is a four wheel dyno.........the wheels "fall into" two seperate rollers, not setting on top of one roller. Also the dyno jet is either rear wheel or front wheel. The front wheel models can do a all wheel drive BUT with some difficulty holding it down and getting a good run without the ECU sensing a traction problem.
GC
post #9 of 15 (permalink) Old 09-11-2006, 06:51 PM
Now I'm confused, was it an AWD dyno or a F/R dyno with the front wheels disconnected?
AWD dyno's require that you remove the wheels/tires and connect the hub/axle directly to the dyno. As stated above rollers are used for a typical F/R setup.
GotStroke? is offline
post #10 of 15 (permalink) Old 09-11-2006, 10:21 PM
You have me confused!!! Here is the dyno service used. Most SoCal performance mfgs use this guy. It is a 1500hp DTS 4 wheel dyno. I have no idea what kind you are referring to......I dont need to know......thanks.
http://www.xs-engineering.com/produc...ter=dynotuning
Dyno Tests FLSRT8 WK1 General Performance Discussion 9 09-08-2006 04:33 PM
Dyno Tests Sgt Stanko WK1 General Performance Discussion 30 08-18-2006 10:56 PM
Dyno Numbers or Dyno Problems SRTUL8ER WK1 Tuning/CMR/Dyno/DataLogging/Gauges 1 06-07-2006 05:48 PM
Jeep SRT8 Dynos 355 rwhp John Hennessey WK1 General Performance Discussion 30 05-02-2006 06:26 AM
