P0441 Evaporative Emission Control System Incorrect Purge Flow - Cherokee SRT8 Forum
post #1 of 8 (permalink) Old 05-13-2013, 03:30 PM Thread Starter
jricher82's Avatar
Check engine light came on last night out of the blue. Hooked up to an OBDII reader this afternoon, pulled the code P0441 Evaporative Emission Control System Incorrect Purge Flow. I erased the code from the system to see if I could replicate it, hasn't come back up yet. Has anyone thrown this code before?
Supposedly the code is supposed to designate that some part of the EVAP control system is no longer functioning correctly. The EVAP system consists of many parts, including (but not limited to) the gas cap, fuel lines, carbon canister, purge valve, and other hoses.
I checked the gas cap, it felt a little loose but wasn't falling off or anything so I have it a few turns so it clicked, maybe that had something to do with it. Just wanted to see if anyone else had experienced anything similar. Thanks.
JP - "If you're not first, you're last."
2008 Jeep Grand Cherokee SRT8 - Magnaflow Exhaust / BT Oil Catch Can / Coil Over suspension / SRT Grill Badge / Pilot Stubby Antenna / Taillight Solutions Wire Harness
jricher82 is offline
post #2 of 8 (permalink) Old 05-13-2013, 04:43 PM
DrSheldonCooper's Avatar
Check to make sure all your hoses are still connected.
Dan
2010 YEEP
DrSheldonCooper is offline
post #3 of 8 (permalink) Old 05-13-2013, 05:36 PM
LASRT's Avatar
Would be my guess^^^
Adam salsbury - 2010 srt8, pwr camshaft installed at stage 6 running 12.6's
LASRT is offline
post #4 of 8 (permalink) Old 05-13-2013, 05:58 PM
Btelander's Avatar
I had the same code pop up today. I tightened my gas cap and check my hoses. Hopefully it was only the gas cap.
2015 WHITE JEEP OVERLAND
2008 BLACK ESCALADE EXT
Brian
Btelander is offline
post #5 of 8 (permalink) Old 05-13-2013, 07:04 PM
WIPLASH's Avatar
Check them hose, you don't want them hose lose. They cause problems when they are lose.
I'm gettting frustrated
with modding
WIPLASH is offline
post #6 of 8 (permalink) Old 05-13-2013, 07:12 PM
Btelander's Avatar
Oops mine wad p0455 evaporitive emissions system leak detected
post #7 of 8 (permalink) Old 05-13-2013, 07:21 PM Thread Starter
jricher82's Avatar
I'll definitely trace the hoses and make sure they're all on there good, just hoping that the gas cap was the culprit and I don't see the code again. I hate seeing that light on, I get all "OCD" about stuff like that and my cars.
post #8 of 8 (permalink) Old 05-13-2013, 11:18 PM
A loose fuel cap will not cause a P0441. It will set an EVAP leak code. Two different codes.
P0700 Transmission Control System Mil Request Sleeper WK1 Troubleshooting / Problems Discussion / Dealer Service 1 04-27-2008 09:47 AM
Stability control system I driving me nuts! PropDr WK1 Troubleshooting / Problems Discussion / Dealer Service 2 02-28-2008 07:40 PM
Throttle Control System Warning Light ON Cdog WK1 Troubleshooting / Problems Discussion / Dealer Service 1 03-11-2007 12:34 PM
