Jeep hard starting up? - Cherokee SRT8 Forum
post #1 of 11 (permalink) Old 02-17-2013, 02:39 PM Thread Starter
sully83699's Avatar
Turned the key and took a good 3 seconds before it finally turned over. Starter was replaced a little over the year ago could it be the battery?
Sent from my DROID RAZR using AutoGuide.Com Free App
0-60 sec 4.27 sec
1/4 mi. 12.23 sec at 110 mph
and getting faster!!!
sully83699 is offline
post #2 of 11 (permalink) Old 02-17-2013, 03:20 PM
One, two, GIT SUM!!
gitrdun's Avatar
could be a number of things. first place to start is the battery, you wont be able to test it yourself without a load-tester, take it to a parts store and they can check it there. next you could have dirty spark plugs, if the battery is fine, check a few of them. if that doesnt work, check the fuel filter, you could not be getting adequate pressure right away from restriction in it, it takes a few seconds to build up. then if that doesnt work, maybe you might have a tiny leak in the fuel rail, that would also take a few seconds for the air to purge out (doubt thats the issue though or youd smell fuel all the time )
hope this helps
gitrdun is offline
The Following User Says Thank You to gitrdun For This Useful Post:
sully83699 (02-17-2013)
post #3 of 11 (permalink) Old 02-17-2013, 05:57 PM Thread Starter
sully83699's Avatar
Went to advanced and they said battery has a clean bill of health and i dont smell anything but the mopar fart when i get on it good so if it does it anymore ill see whats going on with the plugs. shouldnt be do im only at 50k miles
post #4 of 11 (permalink) Old 02-18-2013, 07:38 AM
ekaz's Avatar
Could be the cam position sensor. If it's going it'll take longer for the computer to know where the cam is and start. Sensor is around $20 and takes only a few minutes to replace. It's on the left side of the timing cover.
I'm BAAAAAAAACK....
2015 Billet Silver
past:
2012 300SRT
2009 Jeep SRT
2006 Charger SRT
ekaz is offline
post #5 of 11 (permalink) Old 02-18-2013, 07:56 AM
blahson's Avatar
I get this same problem too. Usually takes 1-3 clicks and I'm up and running, othertimes it take a solid 2-3 seconds.
In my case, it happens a little bit more often when it's cold out. It definitely happens when I don't drive the rig for a couple days. I left town for a week and it took about 10 minutes to start. The longer it sits, the longer it takes to wake up.
Any ideas?? Anyone??????
Joeyyyyy
06 Jeep SRT8
blahson is offline
post #6 of 11 (permalink) Old 02-18-2013, 07:59 AM
Contributing Member
PITTZ's Avatar
There is something in the manual about hard starts and being cold out.
Maggie w/ 2.9 Pulley and 80lb injectors.
Kooks Headers
B&B Exhaust
PWR 224 Cam
Ported Heads
Meth Injection
PITTZ is offline
post #7 of 11 (permalink) Old 02-18-2013, 08:20 AM
blahson's Avatar
I just assumed that cold starts may take a big longer. What I don't get is why when I leave for 2 days, it takes a few tries to get 'er up and running. When I'm gone for a week, it takes 10 minutes to start. It wasn't cold out either, actually about 80*f
blahson is offline
post #8 of 11 (permalink) Old 02-18-2013, 08:33 AM
matt2extreme's Avatar
My jeep does the same thing and one day it starts fine and the next it takes a few turns of the key before it even turns over
matt2extreme is offline
post #9 of 11 (permalink) Old 03-04-2013, 01:27 PM Thread Starter
sully83699's Avatar
Re: Jeep hard starting up?
Well wasnt nothing cuz jeep died today fml lol
Sent from AutoGuide.com App
post #10 of 11 (permalink) Old 03-04-2013, 04:49 PM
One, two, GIT SUM!!
gitrdun's Avatar
Yeah it's cold mode, it shuts down cylinders and alternates between them to make them all work harder thus generates more heat, that's where the rough feeling run comes from. Also turns up the idle speed while doing that. Just wanted tonshed somelight on this for everyone, it is ok for your engine. The concept came from keeping heat in diesel engines , I was surprised when it was on something this small actually lol
gitrdun is offline
Hard Starting after Cam install PEORIASRT WK1 Troubleshooting / Problems Discussion / Dealer Service 5 02-04-2013 07:28 AM
Jeep not starting, not even cranking. Deraynged WK1 Troubleshooting / Problems Discussion / Dealer Service 4 10-31-2012 12:10 AM
trouble starting jeep srt8manny WK1 Troubleshooting / Problems Discussion / Dealer Service 0 06-14-2012 02:47 PM
the Jeep is starting to get famous! retro-king Track Talk 23 05-09-2012 09:30 AM
trouble starting jeep dsalogia WK1 SRT8 General Discussion 1 03-22-2009 05:39 PM
