WOT RPM's get stuck at 4K! - Cherokee SRT8 Forum
post #1 of 28 (permalink) Old 01-25-2013, 08:41 AM Thread Starter
Btelander's Avatar
Good Morning Everyone-
I decided to post because this senario has happen to me a few times now. Anyways, sometimes when I'm driving at 70-80mph and I floor it the tranny will get stuck at 4K RPM's until I let off the gas.
Any help will be greatly appreciated!
Brian
2015 WHITE JEEP OVERLAND
2008 BLACK ESCALADE EXT
Brian
Btelander is offline
post #2 of 28 (permalink) Old 01-25-2013, 10:08 AM
hotrodcalvert's Avatar
This has happened to me before, ended up being a corrupted TCM, I would be getting on the interstate or something along those lines, and as I would toe into the throttle or floor it, the truck would absolutely refuse to pick up any faster, I figured this out after I took it to the dealer and had it reflashed, after that, it ran like a beast, but then went right back to doing it again, had it done again, and just like before, ran good for a little bit, but messed up again, so that could potentially be your problem perhaps, hope this helps.
Colby
The "Silver Bullet" ---- 2006 Jeep SRT8 - Gone but definitely not forgotten
hotrodcalvert is offline
post #3 of 28 (permalink) Old 01-25-2013, 10:14 AM Thread Starter
Btelander's Avatar
Hopefully others will chime in- you think I should start by getting the TCM reflashed?
post #4 of 28 (permalink) Old 01-25-2013, 10:15 AM Thread Starter
Btelander's Avatar
Also, my Jeep is an 09 and in stick mode I need to manually shift. The TCM doesnt look like its aftermarket but who knows.
post #5 of 28 (permalink) Old 01-25-2013, 10:53 AM
Knuckles's Avatar
Try resetting the adaptives on your TCM via the Trinity or Predator and then take the jeep for a ride... Did this just just start to happen or have you just done some work on the jeep and this popped up after that?
Knuckles
Knuckles is offline
post #6 of 28 (permalink) Old 01-25-2013, 11:09 AM Thread Starter
Btelander's Avatar
It only happens at higher speeds and honestly, I dont drive my Jeep a whole lot. I have had my jeep for 8 months now, for 4 months of that it had been sitting in the shop. I have noticed this senario occuring ever since my rebuilt motor was installed. If I remember correctly, last month I tried to reset the TCM adaptives with my predator.
Again, this does not occur all the time.
post #7 of 28 (permalink) Old 01-25-2013, 01:31 PM
Hmmm if its an 09 and you have to manually shift it when its in autostick mode, that doesnt sound correct, cause youre truck is supposed to have the egs53 tcm module in it, which automatically shifts when redline is hit in gears, i have an 06, which has the egs52 module in it, which DOESN'T shift when in autostick, so I had it reflashed to an 07+, so now it does, so if possible, I'd start with the adaptives like Knuckles said, after that, I'd look at a reflash potentially, look on the TCM and see what model it is, if you can.
post #8 of 28 (permalink) Old 01-25-2013, 08:19 PM
WIPLASH's Avatar
It might be a tune issue. Or the jeep is going into Limp mode trying to pretect itself.
What was done to your Jeep?
I'm gettting frustrated
with modding
WIPLASH is offline
post #9 of 28 (permalink) Old 01-25-2013, 08:56 PM Thread Starter
Btelander's Avatar
Check my signature
post #10 of 28 (permalink) Old 02-14-2013, 02:05 PM Thread Starter
Btelander's Avatar
Johan has made revisions but I'm still hitting the reve limit if I mash the as past 30 MPH. Other suggestions? Rev limit is currently set at 6650. Should I start with reflashing my TCM?
Shuddering RPM's on Start 6.1_Toboggan WK1 Troubleshooting / Problems Discussion / Dealer Service 7 10-03-2011 04:33 PM
What's your RPM's @ 80mph? SemperSRT8 WK1 Troubleshooting / Problems Discussion / Dealer Service 18 01-09-2011 02:23 PM
RPM's racing srt8brklyn WK1 SRT8 General Discussion 4 09-08-2009 11:35 PM
RPM's running high at 80mph Twin WK1 SRT8 General Discussion 27 05-19-2009 09:41 AM
High RPM's Andre3000 WK1 Troubleshooting / Problems Discussion / Dealer Service 3 08-26-2006 01:57 PM
