need help with cam install - Cherokee SRT8 Forum
post #1 of 15 (permalink) Old 12-24-2012, 08:39 PM Thread Starter
I installed a fri littleboy cam today. I went to start it, and all it does is start for a few seconds. Could I have the timing marks wrong? Could this be the cause of this? Any suggestions and/or help would be appreciated.
PEORIASRT is offline
post #2 of 15 (permalink) Old 12-24-2012, 09:11 PM
CHUCKTOWNSRT8's Avatar
Did you get a tune for it?
[SIGPIC][/SIGPIC]
CHUCKTOWNSRT8 is offline
post #3 of 15 (permalink) Old 12-24-2012, 09:17 PM
cmn1's Avatar
Did you throw a code? Usually if the timing is off you will throw a code after you get over 3000 rpms. Get in touch with a tuner.
cmn1 is offline
post #4 of 15 (permalink) Old 12-24-2012, 09:43 PM Thread Starter
It did not throw a code, but I could not get it over 3000 rpms. I have not put a tune on it yet. I thought it would run a little bit without a tune. It is hard starting & spits & stutters for a few seconds and then dies. Would a tune fix this? This forum is great. I have guys trying to help me on Xmas Eve. Merry Xmas.
post #5 of 15 (permalink) Old 12-24-2012, 11:20 PM
nyhockeyref93's Avatar
you need a tune lol, sometime they'll run without a tune just idling for a little but most likely going to stall itself out.
2007 Silver Jeep SRT8...that's all you need to know
nyhockeyref93 is offline
post #6 of 15 (permalink) Old 12-24-2012, 11:42 PM
Premium Reformed Member
tugboatchad's Avatar
My lil boy ran pretty decent without a tune. I drove it 70 miles after install, it would stall out several times in the beginning and then it was fine. Do you have a tune in the works for it?
tugboatchad is offline
post #7 of 15 (permalink) Old 12-25-2012, 12:10 AM
WIPLASH's Avatar
it should run ok without a tune but a tune is recommended.
I'm gettting frustrated
with modding
WIPLASH is offline
post #8 of 15 (permalink) Old 12-25-2012, 02:50 PM Thread Starter
if it 's off a tooth,how will it run?since the cam is already a +4.
post #9 of 15 (permalink) Old 12-25-2012, 03:44 PM
I would think if its off a tooth and from what I've been told by someone who did that very thing it will run like shit or not at all. The alignment on the dots during install is crucial.
The Following User Says Thank You to tugboatchad For This Useful Post:
ekaz (12-26-2012)
post #10 of 15 (permalink) Old 12-25-2012, 06:29 PM
cmn1's Avatar
If timing is off you should throw a code. OP, try to keep Jeep running by feathering the throttle. The code usually shows above 3000rpms
cmn1 is offline
Do I need to install new bolts when I install my new headers? crabphir WK1 Intake/ Exhaust Discussion 9 05-08-2012 11:30 AM
Hid install TheSrt8power WK1 Lighting Discussion 11 02-06-2012 03:49 PM
CAI install? SML9284 New England 21 06-13-2010 06:43 PM
HELP on Afe install please alfman9 WK1 SRT8 General Discussion 5 01-29-2010 07:59 PM
HID Install MARK16 WK1 Troubleshooting / Problems Discussion / Dealer Service 3 10-03-2007 03:21 PM
